Are you set up to pull the engine?
Allow 2 days to disconnect and pull the engine. Allow the same to drop it back in.
If you've got solid help, or done lots of engine in/out you can probably do it quicker. For the shade tree guy, there's a lot to disconnect, clean, organise, fix and replace/reinstall.
I'd do a thorough degrease, assess what leaks you actually have to deal with.
A lot of the common leaks are repairable in the vehicle.
If you want to do FR & RR crank seals, than you have no choice.
Pulling the engine out to fix a distributor o-ring leak fits with MUD level CDO* though
*OCD with the letters in alphabetical order as they SHOULD BE!
