Where in the FSM's does it cover Waterpumps?
So. Cal
I see reference to it in the "2F engine" FSM but it shows how to rebuild it and nothing about replacing it.
I know how to get to it and remove it, but what I'm looking for is the torque values for the bolts/nuts or anything else that might be important.
Thanks.
It's in the 2F engine manual, not the body and chassis manual
I assume it would be in the cooling system section, but I don't have an FSM in front of me right now to verify.
Howdy! Doesn't the FSM have a spec table at the front of each chapter that give bolt torque values? I may be thinking of Haynes. John
That's a grey area.
The part number for the bolts for an '87 should be 91612-61040 according to Toyodiy.
6 is the bolt head mark
10 is the diameter of the thread
40 is the lenghth of the bolt
The torque value, according to the table on page 10-6, says it is between 20 and 32.
That's a wide range.
I've personally changed a couple and went with the "till it feels right" setting.;)
I too, don't worry about torque values in regard to water pumps. There are published values for every fasterner on an automobile. Just just a 3/8 drive ratchet by hand and get them tight and I'm sure you'll be ok. No cheater bars or 600lb impact guns...
FSM and engine manual
I have both(FSM and Engine mannual) and the cooling system is poorly covered there is no information at all about heater cooling and oil cooler routing just info on the thermostate. I was really surprised. By the way I am looking for a set of radiator supports for ,85 FJ-60, mine got left on the old radiator and it's long gone. Small bracket with 6 bolts on radiator side and one for the body side. Pm me if ya got a set.:cheers:
Did you get the new pump in? How does it work?
Dynosoar:zilla:
Dynosoar:zilla:
Hey Man, I'm working on it right now as we speak. Took a break for a beer and I'm looking up the torque setting. I'll let you know.
Thanks again:beer:
Dynosoar:zilla:
So far so good...drove it around and no leaks.
I'm going to run water with some cooling system treatment in it for now until I know it's all buttoned-up tightly and to clean out the system before I go with a 50/50 mix.
Dynosoar:zilla:
