where does Kenwood VSS wire go on 1994 80 series? (1 Viewer)
Hi I just got a kenwood 10.1 inch headunit. It has a GPS and also a PINK VSS wire on the harness.
1. Does anyone know where to put the wire?
2. Do needs some type of signal converter to make it work?
Anyone suggest some steps to resolve this? Thx
Ps. I am told VSS checking can be turned off on the kenwood bit I would rather make it work. Thx
zapatius
Indiana
The VSS for the 94 is off the transmission. Get a FSM and it will have the wiring diagram to trace and splice into the wire. I'm assuming this is for navigation?
thatcabledude
GOLD Star
Walton Co, FL
I know nothing about this pink wire or why a head unit would need vehicle speed, but I can tell you from memory the VSS wire in 1994 1fz 80 series is a red wire w/ green stripe located at pin 1 on the IH1 connector near the ECU behind the glovebox.
