Where do 35's rub??
Discussion in '60-Series Wagons' started by Mace, Jul 11, 2005.
  1. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    Figure a stock front end FJ60.
    Has anyone stuffed a set of 35's in their rig without lifting it?
    Where do the tires rub?
    I do have some 2.5" shackles and the fenders have been cut quite a bit.
    I am just wondering if I can get away with flat towing with a set of 35's without too much rubbage.
  2. SHO NUFF
    SHO NUFF
    154
    Nov 6, 2004
    Tucson, Az
    Here's were they rub in front
  3. SHO NUFF
    SHO NUFF
    154
    Nov 6, 2004
    Tucson, Az
    That's stock suspension and stock rims with bfg 35/12.50s.
  4. Mace
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    That's awesome.
    35's away..
  5. Man Jerk
    Man Jerk
    2,112
    7
    Jun 28, 2002
    Colorado Springs, CO
    They rub on the front of the inner fenders when the shackle swings forward. I unbolted the front inner fender and cut the lip that is behind it then tacked the inner fender back on. They also rub on the inside of the rear wheel wells but there isn't a whole lot you can do there unless you cut it all out, but it doesnt do much to the tire.
  6. Mace
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    rear is in a Spring over config.
    The front is not going to be. Most likely a 2.5 or 4" SU config..
  7. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,345
    1,370
    Apr 4, 2003
    Panamá
    but with 4" lift in your front leaves hoy have a really strong spring pack .. don't think so .. ?
  8. Mace
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    yeah, but the SO in the rear is recessed into the frame. If I so the front end it will sit ass low.
  9. BlueCruiser84
    BlueCruiser84 SILVER Star
    2,870
    908
    Nov 1, 2004
    Staunton, VA
    Do you wheel that rig?
  10. SHO NUFF
    SHO NUFF
    154
    Nov 6, 2004
    Tucson, Az
  11. BlueCruiser84
    2,870
    908
    Nov 1, 2004
    Staunton, VA
    that's bad ass. i want 35's
    Brian
