Where did you mount your rear heater?
if you're not going for a full resto, you might try just leaving it out and putting a large toolbox or sub box back there... i find that i very rarely use the rear heater. but then, i don't mind the cold...
try living without a rear heater in upstate NY. I upgraded mine with a larger core and a dual fan. Puts out enough heat to keep it warm with soft top and -20 day.
PS: I don't drive it in the winter anymore, solves a lot of that
Max. Do you have a Factory Service Manual. You can usually pick them up on eBay. You need the 2F motor and the FJ40 Chassis Manual. Don't pay more than $25 for them. Sometimes they spike high, but if your patient, you can get them for under $25 each.
If you need something in the short term for something specific, I live off of Arapahoe and I-25 and you can come copy the pages you need.
I just did a resto on the inside of my FJ and I installed the heater under the driver seat. If you use about a 5/8 shim under the flanges the heater cover will clear the step in the tub. I had to cut about 6" off of the in/out hoses n order to get the fit. There is about 2.5" between the seat bottom and the heater cover. The main reason for this is to keep the kids off of it. "Cuz it makes a cool noise when you step on it". And it gives you a little more storage/ passenger room. :cheers:
The factory mounts are two 10x1.25 captured nuts in the floor in that 'step' right behind the front seats.
Mine now hold down a toolbox. The heaters tend to need work to really heat (flush the core-fan motor bad) and in the south it's not really a necessity. If you do get it working well, it will pump some heat.
My rear heater and associated hard lines and insulation (all of which is in really good shape) is in storage so I can one day sell it on ebay for a price only ebay could bring. :D
took mine out to rhino line and never put it back in, who needs it?
Maybe watch http://motors.search.ebay.com/_W0QQsassZthunderstick12. Right now, this seller is going to get ~$60. But, there are 16 hours left with at least 4 bidders, so the last few minutes could be interesting and profitable ;).
I put mine under the drivers seat.
On the dash....
