I am trying to diagnose a leak on my drivers side, the carpet is soaking wet, etc., etc., etc. I have read a bunch of threads on this and have started the process of testing to determine the location of the leak. I saw mention of both front and rear drain holes for the sunroof; however, I can only see the front 2. How far back are the rear ones because I cannot see them at all. The track goes pretty far back. Are they all the way, and if so what is the best way to see/reach them to clean? What might I be missing?
Thanks.
Thanks.
- Many posts I've read (as you probably have if you've read a bunch) suggest using weed whacker/trimmer line. Stiff enough to push down but not stiff enough to put a hole in the drain hose. Just push the trimmer line back toward the rear holes until you "feel" it is going in and then keep pushing. Sooner or later you should see it come out by the rear wheels.
