Where are the factory front/rear difflock ECU's located, 98 onwards
OZ
I am trying to find out where the front difflock ECU and where the rear diff lock ECU are located in a 100, so I can find some wires which should plug into them, does anybody who has factory difflocks know. Also I would like to know where the harness to the diffs plugs into the main harness if anybody could put their head underneath and have a look. I pressume they probably plug into a sub harness which then plugs into the main harness, this is the point I am looking for as I don't appear to have any sub harnesses.
Thanks in advance
100 TD
If you have a 100 series... you'll probably only have a rr diff lock ecu/wiring.
If you have a 105 series, then I imagine the fr/rr diff lock ecu/wiring might be in the same place as in an 80, but I really have no clue.
Yes 97 had both diff locks and may be the same location, but I am interested in 98 and above if anyone has the info on where they are and how the diff wiring connects. EDIT: Yes i am also interested in the 97 with both locks. My wiring.......I'm not sure....... The switch plugs in and fits but of course does nothing, trying to find all the connectors.
There is a wiring diagram on page 520-521 of the Max Ellery's Toyota Land Cruiser manual for the front and rear diffs. I tried to scan a copy but my scanner is old and won't produce a decent (legible) copy. This publication is printed in AU.
Might ask in the international section. (98+) FR/RR diff locks were not offered in NA.
hoser said:
100TD pm me your email address and I'll send you what little I have.
Thanks Hoser, I have the Ellery book, but it doesn't give the location of the ECU, or the size/shape of the connectors. I am trying to find the location so I can use some of the existing wiring in the vehicle, there are so many unused plugs and wires under the dash and around the vehicle it is unreal, if I can find where they go I will use them instead of running new ones through the firewall all the time making the whole thing a lot neater. I have found that my 03 vehicle matches some 02 wiring and some 03, there is a connector for the front/rear difflock switch behind the blank cover (front or rear locks were not an option with the 1HD-FTE 100, but were an option for the 1HZ 105 platform) and the switch plugs into it, so I want to use existing wiring if I can, if I can find where it goes that is. I have downloaded 03 drawings from the techinfo site and also a 97front/rear and 2000 rear difflock drawing, it shows the circuit but not locations for everything.
Thanks Firetruck41, I was thinking that but will stay here for now, as I believe the rear locker was offered in NA in 1999 and 2000 , so I may get some help yet.
The Differential ECU appears to be on the passenger side kick panel (I guess drivers side for you). It is difficult to tell from the illustrations though.
Thanks again Hoser, my Max Ellery is EP.TO18 1990-2002 Diesel engines including Turbo, it appears that they must have left out the section you have in you manual for petrol engines I presume.
1998 FSM calls the box you want the "4WD Control ECU" and by the diagram it appears to be located behind the "Combination meter" (gauges in the dash). From the very small diagram (SA-164) it appears to be cubish in shape and with a fairly long mounting bracket that extends towards the left.
Whether such things stay the same or move when you switch the steering wheel around ... who can say?
Try and follow your center diff-lock switch harness. It attaches to the 4WD Control ECU too.
Thanks NMuzj100,
I have not found the ECU connectors yet, and one cannot follow the centre difflock loom, it just joins in with everything else then goes to sky blue, like every otherwire in the vehicle, and then comes out somewhere else, something to do with security, but I have found a plug/harness down at the left rear of the vehicle whose part number corresponds with diff lock wiring. I now intend to try to find the other end of this plug, but as said before, each wire goes to different places so finding the other end of all conductors is not an easy task, but I'm sure I will do it. It appears that alot of wiring is in this vehicle and not used, etc etc, I hope to utilise a lot of it. I have found a wiring harness with front and rear diff lock cabling ready for the front/rear switch, but have to find where it goes to use it.
