Wheel Spacers
Discussion in '40- & 55-Series Tech' started by Bryan-71, Feb 11, 2004.
  1. Bryan-71
    Bryan-71
    45
    May 8, 2003
    I have some minor wheel rub on my tre's, was wondering what the best option is for some wheel spacers. Its on a '71 fj40, all stock suspension. I want the spacers on all 4 wheels so it will look semetrical..and while I'm at it some wheel flares would be cool too. Any suggestions, or any complaints about this setup???
    Thanks
    Bryan
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
  3. Poser
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
  4. Bryan-71
    Bryan-71
    45
    May 8, 2003
    How much of a differance will 1/4" spacers make visually, I think it will take care of the rub, but I would like a tougher looking stance....while I'm at it.
  5. Paul_A
    Paul_A
    186
    Apr 1, 2003
    Rosendale, NY
    The .250 spacers will solve your problem but will not make any difference in the look. I use them up front but not in back--no visible difference at all.
  6. Bryan-71
    Bryan-71
    45
    May 8, 2003
    Ok, you twisted my arm..I will go bigger then...mhuahahaha
  7. xumFJ40
    xumFJ40
    376
    2
    May 9, 2003
    Tex..as...Ohhhh...Texas!!!
    I swapped a '79 disk axle under the '75. The aftermarket wheels that I had on the '75 just barely rub the calipers....but it is hard to tell because I can't tighten them all the way. Would .250 or .50 spacers up front do the trick?
    What is the difference(offset?) between a wheel made to fit a drum axle vs. one for the disks?
  8. Rice
    Rice
    4,626
    Media:
    10
    Albums:
    1
    5,740
    May 2, 2003
    GSO NC
    2nd what Paul said. I run 1/4 up front and can't tell they're there.
  9. G-Cat
    G-Cat SILVER Star
    4,357
    Albums:
    1
    1,237
    Jan 2, 2003
    Georgia
    XUMFJ40,
    There is no difference in offset between drum/disc wheels. The difference is that drum wheels have the cneter of the wheels rivited to the outer. (Look at a drum wheel from the back to see the rivets attaching the center to the outer). Disc wheels have the center welded to the outer. The rivets are what's rubbing on your calipers. HTH
  10. G-Cat
    G-Cat SILVER Star
    4,357
    Albums:
    1
    1,237
    Jan 2, 2003
    Georgia
    Spacers. Check www.performancewheel.com. I have some and love 'em (though yer better off with correctly back-spaced wheels)
  11. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    21
    Jan 22, 2003
    Kansastitty
    If you want to go BIG, there is a PAIR of 2" spacers with all lugnuts on the "For Sale Misc" part of the POR board right now.$75, and I have no connection with the seller. I think that puts a lot more strain on your knuckles and wheel bearings, but looks cool. I mean Kewl.
    GL
    Ed :)
