Go to your local Napa dealer and order them. Cost me like 5 dollars each. I had to order mine and it took a couple days but it was worth it. I think new they are like 50 each or somthing. That and a 23.00 dollar honeing set and i was good to go.
[quote author=Jonx4x4 link=board=1;threadid=6189;start=msg49756#msg49756 date=1065838014]
Is there a rebuild kit for the wheel cylinders? Mine just expanded all the way(drum was off), and just gushed out fluid... :-\
[/quote]
ouch, you told them it was for a 70 landcruiser didnt you?
havent bought the kits in a while but for my 71 were between 5 and 8 apiece i think
also make sure when you get them that you get two different part numbers, one of the cylinders has a thicker wall than the other.
Yep... I told them 70... would a kit for a 71 work? The only difference I know of is the brake fittings... they went from the 9mm fitting to the 10mm fitting, or so Ive been told...
Stupid drawbacks... seems like ever time I get something done headed towards roadworthiness, something else comes up!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
