First time posting. Love this site. Great links helped me through my Birfeild repack, after leaky seal. It's all back together for the time being, but I want to replace my bearings. Any suggestions, quality preferences between Timken, Koyo, FAG bearings? want them to last along as the first set did. I heard that Toyota has changed OEM's, I'm just looking for the best for my beast. Thanks in advance for your help.
Even though I always say buy OEM, the Timkins from Autozone are a killer deal and much cheaper than OEM or any of the other aftermarket suppliers. For 80s, Timkins were OEM and the bearings from Autozone are the same part #s. Be sure to get OEM seals and star washers.
If no Autozone, CDan will sell you either Koyos or Timkin, your choice. I have Koyos on my FJ60 and Timkins on my 40 and 80. They are all good.
Never heard of FAG wheelbearings. I guess its "don't ask, don't tell."
if you want to spend the cash then getting OEM koyos is the answer. I however went to autozone and got the Timkens from them which happen to be the other OEM supplier for the bearings. The Koyos are about a 100.00 a whell while the Tinkens are 25.00 a wheel.
I like Koyo's personally--you can see the difference in the machining quality. Just cross reference the OEM part # and go to your local bearing joint and get it cheap there.
Thanks guys. Yeah I hadn't heard of F .A. G. bearings either but it lists as a supplier for Toyota, they're a German based company. I found both Timkens and Koyos listed at about $30 per wheel thanks for the reply!
