Good afternoon noon everyone
I just did the brakes on my fzj80 and found that when I disassembled the wheel bearings for cleaning and repacking that the thrust washers where scored like the outer housing of the bearing was spinning on it. Slight blueing. Plenty of grease.
On reassemble. I found that to get the Toyota specs on the pull test. That I was at almost 30ft Lbs on the torque wrench on the inner nut to get within spec. One side never got there.
So the question is the fish scale test. More important then just setting them to a torque spec and not worrying about them. checking once in a while. New bearings on order soon.
Thanks for any insight
