Wheel Bearing oil seal & plate-replacement?
I am putting together a front hub assembly on a 10/76 FJ40. When I removed the seal from rear of the hub, it was accompanied by a "plate". As I am installing the new seal from my bearing kit, it appears that this plate would interfere with the installation of the new seal. The old seal was "open" on the side that would face the plate. The new seals are "closed" and have a raised portion that faces the bearing.
It appears that this plate retains the bearing to some degree-but the spindle of course is shouldering the load.
Do the new oil seals that are common in the 75-90 wheel bearing kits replace this plate and seal combination or do I still have to utilize the plate?
Thanks in advance.
That plate is used in conjunction with that odd-ball type seal, its a spacer.....nothing to do with the bearing.... I just chunk em in the junk pile......go with the new seal.......
Makes sense. It turns out the plate makes up a difference in the narrow shoulder of the race as well. It is not possible to install this plate with the new race as there is no room in the housing to acommodate it. Thanks for the reply and I am glad I dont have to trash the oil seal after all.
