Wheel Bearing hubs need to be changed in pairs?
Discussion in 'General Tech' started by NMuzj100, Aug 8, 2005.
Thread Status:
Not open for further replies.
  1. NMuzj100
    NMuzj100
    3,493
    49
    Sep 25, 2004
    Gleneagle, CO
    My 99 Toyota Camry needs the left wheel bearing hub replaced according to my mechanic at American Toyota. He found this while mounting my new tires (Cdan) and doing an alignment. (not when I took it in under warranty for front end noise more than a year ago. :mad: ).
    The (St)dealer service writer recomended that I replace both hubs at the same time for $455. I'll have my indy wrench do it with OEM parts instead. Should I do both or just the bad hub. Also after the service should I get the car aligned again?
  2. NMuzj100
    NMuzj100
    3,493
    49
    Sep 25, 2004
    Gleneagle, CO
    Bump - I want to save the bucks if I can but get the best repair possible.
  3. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,341
    1,369
    Apr 4, 2003
    Panamá
    You must need to check the other wheel hub .. if had some signs of damage, I thought the best deal is replaced .. ;)
  4. 72FJ40LandCruiser
    72FJ40LandCruiser
    142
    Jun 2, 2005
    I know the hubs on my ol lady's Malibu aren't hard to change, as I recently put a new one on the passenger side. I only put one on, but only after inspecting the other one. I'm not sure why the one went bad but the other one doesn't have any play that I can see. On her Malibu, you just remove the axle nut, and then there are three bolts on the back that hold it on. Maybe a 20 minute job.
Thread Status:
