Wheel backspacing question
Discussion in '60-Series Wagons' started by BigSur, Aug 9, 2005.
  1. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    Is the backspacing on a FJ60 the same as a later model FJ40?
  2. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    Is the same backspacing needed??
    Yes it is.
    3.5 (or so)
  3. dogboy2
    dogboy2
    996
    9
    Jul 8, 2004
    Portland, OR
    3.5" is the call but the bigger issue with aftermarket rims (if this is where you are heading) is the angle of the face of the wheel (?dish?) and the treatment of the surface details (holes, punch outs, etc...).
    The factory rims are fairly flat across the face of the wheel and the cutouts have no lip protruding backwards towards the rotors. As such, there is no interference or clearance issues with the brake calipers.
    With some aftermarket rims, even if the backspacing is correct, the cutouts may have a lip which combined with a steeper wheel face angle (for lack of a better description) causes the new rim to rub on the brake caliper. You either go with a different rim, grind down the caliper, or run spacers.
    If you are thinking black Rock Crawlers from 4Wheel Parts, you may want to look for something else despite the low price as you will need to run 1/4" spacers to address the caliper issue (ask me how I know ;)....). They do look cool though but from the reports of others on this board, there are some brands that offer a similar rim in the correct backspacing without the rubbing issue.
    HTH,
    -dogboy- '87 FJ60
  4. stinkyfj60
    stinkyfj60
    1,344
    3,386
    Apr 22, 2004
    Roodepoort, South Africa
    And some easier to obtain 3.75in BS that will work too...
  5. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    Well i am looking at some wheels that came off a FJ40 to put on my 60.
  6. lovetoski
    lovetoski SILVER Star
    4,618
    288
    Jul 13, 2003
    Then they should work fine.
  7. hawkeyealum
    hawkeyealum
    175
    Mar 21, 2011
    Overland Park, KS
    Bringing back an old thread:)
    Will the reverse be true as well? FJ60 wheels having no problem on an FJ40 of any year?
  8. stinkyfj60
    stinkyfj60
    1,344
    3,386
    Apr 22, 2004
    of course not...
    same wheel, same backspacing. plus, 60s are disc brake front ends...
  9. hawkeyealum
    hawkeyealum
    175
    Mar 21, 2011
    Overland Park, KS
    But a 60 wheel would work if the 40 had been converted to all disc brakes though correct?
  10. stinkyfj60
    stinkyfj60
    1,344
    3,386
    Apr 22, 2004
    of course.
