Hello, I have 2 wheel with 3½" back space, 1 with 3¼" and 1 with 3¾. Can that all fit on a BJ60 ? And if I put the 2 3½ on the front and the other on the back ?? :-\
it would be alright if you had two of each, but 3 different sizes? Maybe for a spare...
The 3 3/4 may work in the rear, but not in the front. Just be sure that the two front are the same, the rear is not as important, but I might consider buying some new wheels, 3.5" BS wagons can be had for pretty cheap new or used.
Like CruisinGA said, I'd be sure the guys up front were matched just to prevent headaches like pulling to one side. The trouble you run into then is how to rotate your tires for even wear. A complete set wouldn't be too much $$$ if from ebay or the like.
"Proper" rotation calls for moving both rear tires forward and crossing the fronts. (assuming no spare) If you keep both fronts at one backspace and both rears at the other, you should be fine.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
