What's with the range-RS3000?
Shingle Springs, California
My Cruiser's RS3000 will not lock/unlock, unless I'm standing no more than 3 ft. away form it. I dissasembled the FOB, cleaned out all the lint, installed new batt., but it still sucks. Is there an external antenna on the receiver somewhere I should look for? Or is it an internal problem?
Did you make sure the battery contacts still have enough 'spring' in them to keep constant contact with the battery. Same goes for the contact under the button.
Did all of the above with my original fob and it works better....a little.
same here, I can get further if I hold it high above my head for some reason, I tried a new battery in both fobs they are the same,
I have asked the same question before ??? mine used to work from as far away 20+ feet now I have to be @ the side of the cruiser (sometimes when trying to open tailgate, I have to reach around to the side :-[ ) I have dropped my FOB a few times :doh: I keep forgetting to try the wife's FOB (hardly used :D) I too have cleaned the FOB and installed new batteries?
My original key fob does the same thing. Even after changing new batteries >:( I pick up a spare remote and programmed it for my LX450 and it works from a couple car lengths away. Either the spare remote hasn't gotten detuned yet from the tossing around and abuse from daily use or by reprogramming it to the brain it is tuned better to the frequency. I haven't had the time to relearn my old remotes, maybe that's a fix. ???
I have a remote start that is apparently "tapped" into the OEM system, its called AstroStart. There is a small antenna on the inside windshield behind the rearview mirror. I can start the truck, lock and unlock doors from inside my house behind multiple walls, or with the truck 2 city blocks away and around a corner in a parking lot :D this is using the AstroStart remote, I dont have the OEM ones. I wonder if just the addition of a small antenna to your existing system could help you out ??? Could atleast ask your local security shop? :cheers:
Landtank followed the installation instructions on my web site and routed the receiving antenna as specified in the manual. His was wadded under the dash or something like that. His range improved dramatically.
Make sure you start with good contact with the spring and a fresh battery.
-B-
-B-
I'm having troubles opening the files from your site or from Cristo's ??? It's asking for a "password" I'm trying to find the antenna for my alarm.
Or just press the remote againts your chin and simultaneously (sp?) lock/unlock the door. Extends the range dramatically if you ask me!!!
(No, this is NOT April fool story ::slap::)
Frank.
[quote author=sjcruiser link=board=2;threadid=16087;start=msg153882#msg153882 date=1084220915]
[/quote]
Open your mouth too, for a few more feet ;).
Rookie2
Ground your left foot with a suitable strap, raise a half-full Keystone Light tall boy over your head with your right hand and then...... :whoops: Never mind :doh:
sheesh, you guys are all into half-baked ideas...
To get good results, you just need to make a small conical shape out of aluminium foil -make sure it's double-sided and about 7" across- then get 2 wire clothes hangers, straighten them out. Now, put the aluminium cone on your head, grap one wire in each hand, and do some gentle sweeps with your arms while you click the remote with your teeth.
Guaranteed to work at any distance! Try it out in a busy parking lot some time! And will also defintely attract the chicks' attention...!
man, you gotta tell these guys everything... :slap:
:D
E
Reynolds or Alcoa?
geez Dan, why do you think it's called *RS* 3000? As in *R*eynold*s*, :slap:
E
It's about the crappiest range I've ever had with a remote. Changed the batteries on both fobs -- no improvement. It's the same with both my wife's and my rigs. It used to bother me, but then I got used to it and convinced myself that I typically don't need to have it lock or unlock via remote when I'm 50 feet away.
Haven't tried holding it to my chin while balanced on 1 foot yet...maybe I'll try that next :rolleyes:
[quote author=cruiserdan link=board=2;threadid=16087;start=msg154056#msg154056 date=1084235949]
Reynolds or Alcoa?
[/quote]
I live about 10 minutes from Alcoa if you all want me to check into a group buy :D, :slap:.
No seriously though.. try the thing under the chin, mouth open with one arm in the air, ...and tell I'm wrong.
I know.. I know.. "No seriously though.. shut the hell up about it!"
:beer:
Rookie2
The controller should be under your front seat. Mine wasn't. The installer short cut the install and just strapped it next to the steering column. ALl the extra wire, which includes the antenna, was coiled up in a knot and tucked behind the kick panel. Now that it is installed correctly it works fine.
Eduardo,
I just tested it again and the install manual downloads fine. Christo is hosting them for me and the manuals are also linked somewhere on his site. You want to right-click on the link to the ZIP file, save-as and pick a location on your PC (C:\Temp works) then open the zip file and you'll see 13 pages, each a .pdf file.)
No passwords required.
For the naysayers, I opened mine tonight from about 75'. It took 2 tries; on the 2nd attempt I held the fob at shoulder level. Original and well worn fob, old battery, about 20 feet behind and maybe 75' from the left side of the truck. Eat your heart out. :D
-B-
The old under your chin technique does work gotta tell you. When we bought my wifes Avalon, rep there told us about that, and I thought for sure he was kidding. But it about doubles my range for the remote.
