H folks, I searched and saw some stuff similar to this but not exactly this. Today (following from the Redline Water Wetter thread) I did a flush and fill on my cooling system. As always I dumped the coolant from everywhere, filled with distilled, dumped the coolant from everywhere again and then started the flush. I flushed and back flushed everything, then I filled with distilled and took the thing to test run. Well about 1.5 miles away and my temp guage starts rising past 90 which is extremely rare with regular use and then to 100 which I have never ever seen and then finally 108 by the time I got through that light and pulled over. I had both heaters on but no heat. I'm sure the thermostat stuck. I simply waited about five minutes, turned it on again and felt for heat but there was none. Then I waited another five minutes and repeated this about four times every five minutes. Finally I waited about twenty minutes and just occassionally turned the key but not the engine to see the temp on the factory gauge and the greddy gauge. The temp never exceeded 108 celcius on the greddy and got nowhere near the red on the factory and from there slowly lowered to 80 at which point I filled up the rad with some more distilled (about .5 to .75 liters) and then drove home the 1.5 miles. On the way home the temp was about 90 and as I pulled into the neighborhood I felt some heat. As soon as the heat came on the temp dropped down to 82 and stayed there.
Soooo, my question is, what is the right thing to do in this case??? Should I have continued driving to force the water pump to open up the thermostat or should I have stopped driving as I did. Is this 108 a real 108 or is it a bubble temp of air in the system??? Is this cause for concern??? Thanks fellas.
