Hi everyone!
A few details to finish the first stage of the build. Mechanical stuff mostly.
All the following, have been done:
All fluids, filters and belts have been serviced. Water hoses replaced with brand new OEM ones, as well as thermostat, inlets and outlets.
Vacuum piping replaced.
New battery.
All suspension bushings have been replaced with OME bushings (yellow ones)
Front knuckle rebuild, with OEM bolts and stud replacements.
Transfer case with new seals and bearings. All cleaned up, it was a mess when I bought the truck.
OME 2' lift kit with caster correction bushings.
Next stage will be the body shop, to fix some minor details, remove factory rails and ribs. Maybe in the future I will wrapped it in white? What do you think about the color change?
Will also be installing Safari Snorkel, ARB Drawers, and ARB Alloy roof rack.
So now its time to drive it and enjoy it, and make sure everything that was serviced, works fine. It currently has 202.000 miles on it, engine runs well, transmission its a bit rough.
Here are some pics so you guys can tell me what you think about my girl!
CHEERS!
New battery.
CHEERS!
