What would it take to go electric?
Oregonian moved to Vegas
This has been on my mind for a while and I wanted to see if we could explore the possibilities. I know the 80 is probably the last choice for electric transportation given current technology... but humor me.
What components would need to be replaced besides the motor? What electric components are currently available for those parts needed for this transformation. Would it make any sense to keep the gas motor and integrate an electric?
:cheers:
It would be very difficult due to the weight of an 80.
You are going to make a 6000# vehicle 7000# plus with batteries alone.
It will take a HUGE battery bank and an electric motor with a HUGE amount of torque. Its not totally impossible because any electric motor will have an output shaft that you "could" adapt to.
It seems that battery technology is moving forward at warp pace and the Li bats are amazingly light, powerful, and reliable. I read somewhere that there are electric motors that will make the stock trany unnecessary - therefore eliminating ? pounds...
But if it was going to be done what other items would need replaced? steering pump? brake system?
Hybrid diesel - think locomotives. With a small 4 cylinder diesel, you could still have vacuum for the brakes, AC, and everything else. Use a small bank of batteries to store power generated from braking that could be used for acceleration.
My brain has been wandering towards the idea of a hybrid hydraulic system. Same idea, but with accumulators instead of batteries........with enough accumulators, you could store enough energy to have some impressive acceleration for a short time.
I haven't worked out many details, just bouncing ideas in my noggin :D
Tony
It would take a very thick wallet and a "who cares" attitude about dumping money into something that might never work properly...just think of it...GM is asking for 25 billion to help them with "alternate" fuel vehicle research...
Crazy Horse Lincoln?
Neil Young's 1959 Lincoln Continental Convertible in my hometown! $120K/2 tons, so maybe $180K for an 80-VOLT?
Singer focuses energy on electric car - CNN.com
There's a red Samurai somewhere . . . this blue Samurai Googled up: Daniel Stewart's 1988 Samurai Sooz
My :princess: is threatening to push one of 2 Samurais in the garage OUT, so she can pull her LX450 IN. I have no doubt she could. The LX, no way!
Why not go with a small gas cooled fusion reactor? The reactor itself won't weight too much. A brayton cycle power converter (small jet engine running backwards) could generate a few kW and only weight a couple hundred pounds. The only question is how to dump the heat....and where to get highly enriched uranium. But that's in the details.
Good luck:)
internal combustion/electric drive
I've been kicking this around in my head for a couple of years now.
Start with a small air-cooled diesel prime mover. Back that up with a generator of sufficient output. Run the power through some serious cables to a potentiometer with a foot control. From there, through a polarity switch (for forward to reverse switching) to the motors. I personally prefer the motors at each diff pinion shaft. Less modification to the axles that way. Others have said they'd prefer a motor at each wheel. Either way will work, if you don't mind doing the necessary mods.
A large capacitor can be used to store braking energy for re-acceleration.
Since I am familiar with internal combustion powered welders, that's which way I'm leaning. The hard part , I think, would be the motors and mounting them to the axles.
I think this can all be done for about the price of an 80 when they were new. This includes the purchase of an 80 with blown motor or tranny, used welder/generator and doing all the fab work myself.
When I'm financially solvent again, I plan to pursue this idea more.
Just buy a flux capacitor and you can run the 80 on garbage.
They only cost $175,000 But think of all the fun you can have traveling through time.
LINK
Dynosoar:zilla:
