pb4ugo
Id do your 4" lift and tires and buy the appropriate size winch and recovery gear, along with a nylon snatch strap. A winch will drag you over or thru just about any obstacle in front of you. Next join a local offroad club and gain some seat time and see what other folks have done. Most folks wheel with at least 1 other vehicle so they can help each other thru the trails. Later you'll probably want at a minimum a locker in the rear. If you decide to go with something other than a lunchbox locker, you should consider installing lower gears at that time. ,4.56's are a waist of money, theres not enuff difference from 4.11's. 4.88's are not much better, but id install that ratio into my 40 again. Anything taller will effect road driving rpms considerably. After these changes and you want more gearing, then look at major driveline changes and try to build lower gearing thru the trans and transfer cases to spread out the reductions thru out the drive line. Try to keep blacktop drivabilty with lower gearing off road. There are many combinations to achieve these goals. Do your research, and try to make wise desicisions so you dont have to go back and make major changes again.
