Hey guys I have a bizarre problem.
The needle on my speedometer was bouncing for a few weeks while driving, it would tell the speed but kept bouncing while doing so, and then it eventually stopped working. When I pulled out the speedo gear from under the car I found it to be worn out. No biggie, ordered a new one and replaced it. The speedometer started working again but the needle was still bouncy, I figured it was probably an issue with the cable. A day later, the speedometer stopped working again!
Does anyone know what could possibly be causing my speedo gear to wear out in under 24 hours? My theory is maybe the cable is old and super dry causing so much friction with the speedo gear that it doesn't spin as freely causing the metal gear to grind it? No idea if that's possible but it's the only theory I have.
I have a new cable to swap out with, but the guys who restored my car welded or glued the cable behind the cluster and I can't pull it out to replace it. You can see some grey stuff in the photo below, I think its glue. I'm worried if I force it out harder than I'm already trying to remove it I might damage my cluster and don't have $300 right now to spend on a new one.
