What to inspect when buying a 60???
I am in the process of looking at a couple of FJ 60s - both in New England and both under $5k. I have never purchased a LC before (sorry if my questions are amateur).
Can anyone advise on what key things/issues I should look for when doing my inspection of the vehicle? What are the real show stoppers or potential problems to be careful of? Is it drive train stuff, frame rust, other?
Any suggestions would be very much appreciated - also hints on how to perform the inspection. I just want to make sure I am looking for the right things don't make some really stupid basic mistake.
Thanks in advance
Surf around this site, you'll finds tons of info, look at the FAQ's section. In the Northeast especially, look for RUST, you're sure to find plenty of it. Pay close attention to the frame rails in the rear near the spring perches and gas tank.
RUST RUST RUST
If its basically stock, I wouldn't want to see much rust, if any for 5k, you could find a pretty nice zero rust cruiser for that kind of money on Ebay.
other than that its just the usual stuff, make sure nothing is missing, not too much leaking, works like it should.
check the front steering knuckles to make sure that they are not in need of new seals. If they are VERY wet and dripping grease/oil then pass.
Rust; 4x4: engage, run and disengage; compression check; suspension (original suspensions have a tendancy to sag and lean to one side); steering play; and again check for rust.
The 2F should sound about like a sewing machine when tight/running correctly. A slight valve ticking is normal for this motor. It may seem slow to you (normal) compared to newer cars with V8s and strong V6s. As mentioned above, RUST in your area. There are some nice rust free 60s running around here in West Texas, though none for sale recently that I've seen. 5K should get you a pretty darned nice rig. I saw a RUST FREE very nice one here go for 4k off a used lot 9 months ago. I should have bought it to resell to you guys; it ran like a top, I mean a sewing machine.
Check above rear rear spring perch as stated, inside frame rails especailly near the muffler and exhaust. the body rust is always worse than it looks if the bubble is bigger than the size of a BB. When you do to check them out call ahead and ask that they are not warmed up when you get there so you can see how well they start. Once it is fully warmed up it should Idle between 650 - 750 rpm's, a cooling fan inside teh drivers side fender should come on after it is shut off. Where are you located?
Good luck.
ERICH
Depends on your willingness to wrench on it. Stuff like front-end rebuilds, leaky hoses, carb issues, etc can all be fixed in your garage. If you fix them yourself, the costs aren't bad. If you have a mechanic do it, it can get real expensive.
If you don't want to spend time under it, I would look for one with minimal leaks, easy starting, smooth running, proper shifting, 4WD engagement, NO electrical problems, AC/heat working, etc.
If you like to wrench on stuff, look for one with no major engine/tranny issues and no major rust. Make list of everything else you see that needs attention and use it to negotiate the price down as low as you can. Hand over the money, drive it home, get addicted to this site, and start wrenching.
Good luck!
Start smooth, idle smooth at 650 to 750 rpm. Bad idle can point to numerous problems from vacuum leaks to emission problems. Nightmare to track down. Run out good with no flat spots in the acceleration. Will be a little slow these are not race cars. No funny noises other than slight valve tick from the motor. Lastly check for rust. Get underneath and really investigate the frame and underside.
New suspension (high $$), re-arch and add-a-leaf (less $$), tilt your head as you drive (least $$). Some would even suggest a complete spring over axle modification (more more $$$$).
FJ-60 in New England
I have a 83 FJ60 in Connecticut that I just purchased from Nevada that I was going to ship
to South America but found out that it is a big hassle to import there. So I am considering selling it. It has low compression in one cylinder and I was considering replacing the engine with a used one available locally with about 110K miles. Truck has only one two
easly repairable rust spots in the rear wheel body arches. The frame is absolutley perfect. Original paint. I will sell it for what I paid and eat the shipping cost. The used engine can be bought for $300. I have never seen a New England truck without frame rot so be very carefull. Looking for $3000. allfoden@aol.com
