What stuff runs on these fuses? (2 Viewers)
Red Beard
Cruisin'
Kennett Square, PA
Website
cruisin4parts.com
What stuff runs on the "DASH" 10AMP fuse in the engine bay?
Also, what runs off the "CIG" 15AMP fuse in the fuse box?
(Trying to run down a short circuit):mad:
Your owner's manual or a FSM will tell you everything that runs off every fuse. Or, you can find out the easy way; take out the fuses in question and find out what don't work.
Also, I agree with Curtis...:confused:
Haha, that was wayy back when I first joined this. Didn't know the difference.
Any 'aftermarket' stuff (radio's, cb's, alarm's) that might be wired wrong/poorly causing the grief? Wires routed wrong that are now pinched? Too many things on a circuit?
One of those three things are usually at the root of electrical demons.
Still says "locked"... The term "locked" usually refers to f/r lockers. ALL 80's came with a center diff lock.
Honestly, it should be called a 4WD button.
