I'm going to hang these from my CalamariDog recovery brackets.
If Cdog used my original FRB design, which I am sure he did, then you need the 7/8" Bow/D Shackle. The "pin" for a 7/8" Bow/D shackle is 1" diameter. FYI: The smaller Bow/D Shackles are not wide enough to straddle these FRB's...so there is only one Bow/D Shackle size to consider.
fish2live,
Unless Cdog changed my original FRB design you need a "3/4" D/Bow Shackle. These have a 7/8" diameter pin...which fits nicely through the 1" hole in the FRB.
D-Ring Shackels: 1", 7/8", 3/4", 5/8", 1/2"
And if you're 100 is really stuck I recommend utilizing two FRBs, one on each frame mount location, and using a rated recovery strap connected to each FRB and then your winch line connection. You want to keep the angle between the FRB/frame leg and the connection at the winch line to 120 degrees or less to help prevent the left and right frame legs from trying to collapse towards each other...
Here's a crude pic...
's
Thanks. I already ordered with 4x4 Connection, but will have to change my order now.
The question is, do I paint them OSHA yellow...?
i would think in a few months maybe we could get it done. Now that we have the proper sources for everything it should roll smoother then before. I would take two FRBs
You wanna take that lead?![]()
Mac, see this thread, fish2live got the 7/8s with 1" and they didnt fit...same thing I did.
https://forum.ih8mud.com/100-series-cruisers/207639-tow-hooks-delivered.html
Spress, which one is it?
or is it this?
