What size hose is this?
Discussion in '40- & 55-Series Tech' started by Mr. Toad, Aug 1, 2005.
  1. Mr. Toad
    Mr. Toad
    1,704
    Media:
    3
    Albums:
    1
    70
    Feb 7, 2005
    My '75 2F has a hard coolant pipe mounted horizontally on the head on the passenger side just above the distributor. A soft hose goes from the back of the hard pipe to the heater inlet on the firewall. A standard 5/8" ID heater hose fits those fittings.
    The front of the hard line connects to the small metal inlet on the hose at the bottom of the radiator. 5/8" ID hose is too big, and 1/2" ID is too small. Does anyone know what size hose to use here? Or are these joints made of unobfittium?
    Thanks in advance,
    Shawn
  2. CruisinGA
    CruisinGA
    6,168
    16
    Mar 27, 2003
    Georgia Tech
    Always used 5/8."
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    It is very possible that over the years, corrosion has caused enough material to be removed so that a 5/8" heater hose will not seal on it any loger....been there.
    Replace lower metal tube piece. Early trucks this was a fitting that could be replaced, later trucks, this was a one-piece affair...
    Good luck!
    -Steve
  4. Mr. Toad
    Mr. Toad
    1,704
    Media:
    3
    Albums:
    1
    70
    Feb 7, 2005
    Sounds reasonable fellas. The lower fitting is replaceable. I'll give it a try. Thanks again.
