What size bolts are used to Support Factory Tow Hitch
M12 X 1.25 X 35
Auto Zone, ACE, Lowe's and Home Depot.
Make sure the grade is the same or better.
How does one distinguish between grades?
Marking on the bolt head. No marking means standard or low grade and the higher the number or the more marking means stronger material.
As I recall Draw-Tite hitchs for the 80 series came with grade 8 and you shoud torque them at least at 75 lbs. Tomorrow I will look at a installation sheet to double check.
Just go to Lowe's or Home Depot and look for marking on the bolt head with 8.8 stamped on them. That is the same marking that you will see on original bolts that secure the hitch receiver on the frame. Then there is 10.9 grade but I opted for the 8.8 since they are a little cheaper.
