What leaf springs?
Hey guys, I'm new to the site. I bought a 77 FJ40 tub and I'm doing a frame up build. I'm in the process of collecting parts right now and hopefully you guys can point me in the right direction. I'll give a little insight as to where I'm heading with this:
Using a stock frame.
Drivetrain is going to be a SBC, TH400, NP205 (twin sticked) GM D60 front, 14B rear.
I've got a set of Humvee BL's and plan on running 36" Irok's.
Propane. ;)
I've got most of the parts (still hunting for late model windshield, hood...doors.
My first (and not last!) question is spring choice. I've read quite a bit of material, but I've heard so many different opinions I'd figure I'd finally sign up on a LC site (I found this one from a link on PBB).
I'm looking to stretch out the wheelbase as much as possible with the stock frame and I know spring choice is going to play a roll in that. Would you guys use 63" chevy's front and rear? Something different?
Thanks in advance and I'll keep you guys updated with the progress. I'm over on www.timbercrawler.com mostly (since I'm a moderater there) so you can follow along the buildup there too.
For now....here's a pic of how it's all starting. Yup...it's a uncut tub (for now :eek: )
~Jason
well first off, depending on your skills and what you are building this for?
rocks, you will not be happy on 36" tires on a 14b, 40" min IMO.
max length, suggest links and coils or coilovers. Otherwise stock spring SOA,
you can stuff small 36" tires, and have a somewhat extended wheelbase.
clean uncut tub, sell it buy a not so great tub cause it sounds like your going to
abuse it anyways.
Building for Pac NorthWest wheeling. Mud, trees, rocks...you name it. Skills is not a problem, but money is not growing on the trees. That is why it's not getting linked up with coilovers.
The 14 is getting shaved...so clearance will not be a problem either. ;)
Pic is from PBB...but you get the point.
Stock springs? I've got access to alot of them....I've always heard they don't flex as well as others. I'll look into that more...
Your right. I am going to abuse the whole thing. Plan on competing in Team Trophy Challenge again too. I know cutting up a clean tub is going to make some of the purist LC guys cringe...but that is part of the fun. :D
Here was my friend and I at TTC in 03. Yes, we are beating on a 45 too. :flipoff2:
This is another friends FJ on Mog axles. This is what I'm going to do with the tub eventually...minus the portals.
Keep the advice coming guys!
whats the point of using a tub at all?
or why not just channel a chevy.
cowl and bib and tube the rest.
go buy a complete $500 or less cruiser, SOA, throw lockers and a V8 in it, cut it
up till your heart is content, add a extra chunk of framerail, chop the
top, tub it out, weld a hardtop on, hood scoop, blower out the top, underbody neon, whatever pops your cherry. And be way ahead in $$$$ then what it sounds like you got planned.
where do you put the 4 foot coilover, through the passenger seat. mogs on 38x11's? WHERE IS THAT RAINBOW ICON! Or wasnt there a little pink fairy icon also?
have the skills but not the money, but using pretty expensive axles to both
purchase and build when 1/2 ton axles stock cruiser axles, toy mini axles will survive and will leave you with much better diff clearence both depth and width.
th400 np205 not that cheap either i might add.
I suggest spending less $$$$ on expensive drivetrain and more $$$$ on setting it
up right, within the budget. Most expensive POS will be outperformed by a better setup rig.
links are cheap if you have skills/tools.
IMO 36" tires on a 14b if it is street duty only, even if you shave it, grind it, hack it, box the bottom, turn the ring gear to 10" or even 9.5", build a custom center section, etc...
maybe this thread just got me at a bad time, long day.
just sad for someone to burn lots of $$$, hacking up good parts when they should have just gone with a HEEP ( insert rainbow).
BTW not a puriest but do have common sense.
Since you seem to not want to answer my original question(s) and attack my whole purpose and build up idea's....I'll play your little game.
I'm using a FJ40 cause I like em'. Just because I see cheaper/easier ways of doing things and have different goals/idea's than you doesn't mean I can't use a Cruiser to wheel. You may like all the pretty paint, your wonderful 2F tractor motor, birfields....paying way to much for junk 40 parts doesn't mean I have to do the same.
If I wanted a redneck cut up fullsize truck, I'd use the one I got the chevy stuff from in the first place. As you can tell from the photo's above, I'm not into JUNK.
The 38's are gone and 44's sit in their place. This was right after it was done being built (your rig may be that clean) but here's a few more pics of the hydro rear steer, how the "4 foot" coilover dosen't go through the pass. seat, and I'm sorry, but link's are NOT cheap when you use parts like this and all the tubing is Chromo.
Junk yard leaf springs are a tad cheaper than a set of 4 king coilovers and 16 $50 dollar a piece hiem joints.
I didn't say I was broke so don't assume. This is a 8 month project to get it on the road. I'm not cutting corners, but I don't the extra $2500 for the link setup like on the 40 above. Yes, I'm using some expensive axles...if you pay top dollar. I bet your Longfields cost more than the truck I bought as a donor for the drivetrain.
So, 36's are street tires only? With 36" Irok's and shaving the 14b like above...I'll have the same clearance as having 39.5's.
You may have had a bad day or whatever, but you sure didn't make much of a impression on me for my first dealing with anyone off this site.
If you want me to explain the use of 36" tires...it's because a stock frame won't allow for the wheelbase needed for much more. I'd go ahead and run the 39.5's I want if I was going to tube out the rear section and run links at both axles. I'm not. I'm not looking to build a "buggy". I'm looking to setup a decent FJ40 and not have a lame Jeep like the rest of the sheep.
I guess I have no common sense. Thanks for the big help. :rolleyes:
FJ55 leafs are popular for the added wheelbase and added flex. They move the axle about 3 1/2 inches each so the 90" wheelbase becomes 97". Check out the tech section for more info. Are you shortening your axles or outboarding your springs? As for 36" tires I run 35s on cruiser axles without problems and will go bigger when I replace. Probably 38.5 but may try 37s. Not sure yet. 35s are not big enough for my liking. ;)
well i think your setup sounds like a pretty good build. actually, almost identical to the project i'm hoping to start this fall (after i get my house gutted).
i've only been a cruiser head for about 10 years, and have only been really trashing around since i found this site a couple of years ago.
as for your springs. if your just going to use a soa setup, i would reccomend stock 40 springs, or go with some springs from a 55. once sprung over your 40's stockers will probably be more flexy then you think.
anyway, i'm not the most super-hardcore person on this site by any means.
i don't even do my own welding (never got around to learning). but i think your in a good direction.
AND WELCOME TO THE SITE BROTHER!!!
oh, and don't listen to hammerhead.
he's from sothern utah (big wierdos down there :)
Ah hah.......I'll chime in......
Dude, welcome to Ih8mud. I read the thread, you know your s***, no doubt, but so does HI^C and he's gonna give it raw. Hope you understand.
I, for one, am pretty interested in seeing your project progress. I'd hate to not see the progress 'cause your post was met with more questions than answers.
Keep us posted.
Welcome to the site.
Tom IV
Thanks guys for the warm welcome. I expect a certain amount of jibbin'...I don't take things personally!
I'll look into the FJ55 springs...they sound like what I'm after. I'm looking to stretch this thing as far as I can with the springs! I'm running my axles full width, but with the 7" of backspacing on the Humvee beadlocks, I'll be pretty close to keeping half the tires under the fenders. :D
Don't worry about me leaving you guys hangin with the project either. I'm here for tech questions/answers, but also to share my buildup with some fellow Cruiser junkies. I think if I can survive PBB, moderate on TC....I can handle one guys raw opinions. It's good to see he's not the voice of the atmosphere on this site....I know there is ALOT of good tech here and I'm hoping to tap into it!!!
One thing I can't stand though is being judged by your post count..."other" 4x4 sites are famous for it!!!
I can tell you seem a bit new to this.
i did have a long day so i am a bit tired, for that i apoligize.
links are links, coilovers are different, you can link any spring type.
i say links i mean links, there is a good 4 link thread and a good
coil spring thread here, take a look. links do not need to be chromo,
you do not need to build anything out of chromo. no need for $50 heims
either. you can use junkyard coils (in that coil spring thread).
do a bit of search you will find posts by woody, running cruiser axles
on 38.5 and using them very well. pretty stock i believe also.
cheap donor is good. so i assume you have sbc th400 to 205, d60f and 14b.
running numbers
th400 to 205 and adapter 24.37+4ish+12.25=40.6~ running long waterpump
on a sbc, placed within 5"s of the radiator (fan clearance), on stock wheelbase
you will have about a 15" driveshaft on stock cruiser axles. you gain about 3 to 3.5" with spring reversal or fj55 springs. with the large 14b, driveshaft length can become a problem.
little dark out for the the 14b pinion length difference vs the cruiser. can get it tomorrow if you would like.
Now desired lift, amount of suspension travel, type and action of suspension, driveshaft type, ujoint operating angles, axle wrap or any rotation will all combine into what you will be able to run without self exploding. all with wheelbase length a large determining factor.
end of part 1
the whole no wheelbase for anything bigger then 36" tires is something
i have never ran into nor heard before? is this a mathmatical formula
of some sort?
ok shaving like shown gives you about a 5.5"ish CL to bottom of dif about 1.5" total off, which does clears up alot, its the about 14" of center chunk width that becomes the problem.
running 36.8" tire on 16.5 rim, 10" sidewall, air down to 5 psi about 3" sidewall, yeilds less then 6" diff to ground but you still are cutting the 14" wide path with the less then 6" clearence. rough numbers used to guessimate and show in numbers what i ment before in words. hope my math is ok? i do not like the irok balloon tires.
fell asleep for 10 mins, lol.
I would consider the pics to be a very buggified cruiser, you mention not building one but doing the same thing as the one pictured?
there are many things about that cruiser pictured that are buggin me, lack of cutting brakes, miss mounting/measureing front coilovers hence the holes in the hood, only about 1.5" up travel in the front, about 2" up travel in the rear. These would be large items with a build in this $$$$ range. I guess "to each his own"
I do like that cream? fj45.
I think you will probably end up with spacers 1"ish on the front with the hummer beadlocks, tire CS is just a bit too small to cover, and steering arms are in the way.
I am glad you can see what a very large budget can build, but many many others are built for much less. get a sponser? lol.
You might want to also post over in the "Hardcore Corner" subforum on IH8Mud. Some of the folks there who may have experience don't make it to Tech here much. ;)
I'm at 101" WB on a stock cruiser frame... my 38.5's don't seem to mind, either. Take stock 40 springs, shove 'em short side forward as far forward as ya can... that gives me 7" of WB stretch... Stock 7-leaf Waggy's out back, short side rearward.
I was wondering about the amount of uptravel with the portals and a stock-looking FJ frame... Didn't think I'd be able to get much uptravel in the front because of the frame rails.. How much does he get? I'd really love to find out alot more about that rig... PM/email me if you would?
I get PLENTY of usable flex out of this setup, and am around 81" tall overall.. nice and low.
Cool. I'll give a run down on the buggy-mog axled FJ first. The frame is not stock...its' all custom built around the portal axles. The reason for the limited uptravel and the coilovers sticking out of the hood is the portals. You don't have much room to put them under a FJ like that and not sacrifice something somewhere. The down travel is amazing...this thing works.
As for using chromo on the links..your right. You don't have to. If you look close, everything on that FJ is overdone with big money in it. I think the rear steer joystick cost over a $1000. Anyway, I don't want to debate his design and workmanship...there are things I don't like about it too. I just posted it in the place to show what I would like to end up with tub wise someday....and that is a ways down the road.
I know the 14b is a pig...and this why I'm wanting to stretch the wheelbase as much as possible. If you guys think I can run the 39.5's...I'd be more than happy to do it. I was wanting to run the 14b since it's darn near bulletproof from the factory. I'm liking the 1.5" axles, 4.56's from the factory.....do you think I'd have better luck with a D60 rear? I just didn't want to sink big money into a rear just to get it as strong as a 14b is stock.....putting on D70 spindles just to fit the 1.5 35 spline axles is alot more work..and money. I don't think the pinion sits as high on a D60 than a 14b either...if I'm not mistaken it's around 1.5" lower. That's a big difference when your dealing with short drivelines.
Eskimo...I'd love to see more close up pics of your springs and how you mounted them up. Your wheelbase is about perfect from what I can tell. Major surgury to the rear of the tub to make room too! :D
I can put you in touch with Jason (the owner of the Mog-FJ40) if you would like to talk to him. I have some more pics if you would like those too.
The 45 is pretty sweet and setup nice too. ARB's, NVG4500, Atlas II, SBC....rear coils and linked. It's a rust free complete 45 too. It's also good to see it used!
Thanks again...and I'll keep my posts over on the hardcore corner if you guys think I'll have better luck with answers over there. ;)
Oh...and the spacers for the front axle are 1.25" for steering TRE's and arm clearance. I still have to chop out my run flats on the Humvee wheels and paint them. Throw the junk GY tires away too.......so much to do!
for that kind of tub, sell yours, buy a cowl section, build or buy rear portion. I would suggest doing this first, no sense building a cage on a tub that your going to cut up anyways and change the cage to fit it. costs you will be ahead if you build, probably behind if you buy, but wont have to redo anything.
it was the 14b and 36" tires that really dont combine together well, not them individually.
36" tires are good on the smaller axles, and the axles will survive just fine.
run the 14b, figure gearing and any street driving it needs to do, go with the biggest tire you can, that allows desired crawl ratio and streetability if you choose to maintain it. IMO 38s or larger with that shaved. they also offer a 5.13 factory gearing, and a cab and chassis with 63" wms.
d60 rear is about 3/4" more dif clearence then 14b stock, but costs a good bit more to build. most can have the spindles bored out to fit the 1.5 shafts, some came factory large enough to take the shafts. pinion height i have not measure difference, but cv rear really wouldnt matter, pinion length in a cruiser body might.
eskimo has nice amount of trimming, nothing major other then no front fenders.
so many spring and wheelbase options, along with the ability to offset spring pins, redrill perches, move the spring perches etc... you could end up with close to any wheelbase you want. There are a number of threads on pirate asking basically the same what leaf springs. I suggest searching or finding aftermarket spring manufactures catalogs, they list all the spring dimensions along with spring rates pin placement etc..... these will give you very very close to stock spring specs (use the lowest lift springs for spring rates) as far as pin placement, different on the free arch etc... I keep current catalogs right next to me for this same reason, i think i have 5 catalogs now. and to use them for lift coils as well, LOL.
dang it forgot, you probably could ask this thread to be moved over to the other forum by the MOD.
Good deal! Thanks for the info. I'll stick with the 14b if I can figure on running the larger meats. I was told that the 36's are gonna be pretty maxed out using a stock frame....like I said...this is my first cruiser so I'm a newbie with the "what works" stuff on them.
What's the tub worth? Cutting it down is really in the future....I just want to get this on the trail to wheel. It will be a trailer queen, but I want to retain streetable manners and legalness to run into town or to a trail farther down the road if ones around. I was thinking 5.13's with 39.5's....should be a good match with the auto and 205. I need the 67" 14b to run the beadlocks so the C&C is out. Harder to find too.
I'll keep up my research since I'm still up the air about the springs. I know the wheelbase I'm after..what tire I want to run...what my drivetrain is too. I guess I'm at the crossing road of what springs to run.
Picked up my Scout II box...gonna tap it and run assist for the big ol' heavy tire/wheels I'm running. The write up by billavista on PBB isn't very clear on where to tap these boxes...you guys know of a better writeup?
Oh....MODS.....could you move this thread to hardcore? Or should I PM one?
Thanks for the advice!
some research to do, LOL.
if your loaded with 4.56s dont worry about going 5.13s, saves you the $$$$ plus setup costs if you dont do them yourself. you can detroit the 14b and not worry about resetting it up. and do the d60f and set them up yourself, not all that confident just dont drive on the street in 4wd. Sounded like you had x military axles? so already d in the rear?
hydro assist, well the pics show the most important tapped part which is the lower port that goes into an exsisting port. the other port is hard to see placement in the other pics. there is a good pic of a scout done, but dont remember where it was.
If you dont feel like rebuilding the box, take off the alum covers weld on extra plates, tap them. pipe fittings tend to cause the covers to break easier, so it is recommended to use the oring style fitting into the covers. two guys i know run the scout boxes done this way and never had any trouble with them, 2" rams 44" tires.
what is it worth, well depends on what the buyer pays. someone on here just sold a tub and front sheetmetal for like 1400 on ebay. but conditions do vary.
