What kinda rear brake pads should I buy (1 Viewer)
If I buy aftermarket rear pads what kinda material should they be. I put some carbon\matalic on the front, are they any good????? cause my back brakes are sqeeking like hell and they are pissing me off.
Landpimp
GOLD Star
Gig Harbor WA
I just did the 99 LX, used OEM LAnd Cruiser pads(same as LX, and prolly less money) and am very happy with them, the 100's have good brakes so IMOP there is no need for anything but OEM pads.
Any other suggestions? OEM vs. aftermarket?
I need front and rear pad sets.
Also, anything else needed for a pad replacement job? I've never done one before, but it seems straight forward.
Thanks
Turquoise Trail, N NM
Thanks
Don't you also need to replace the anti-squeal shims w/ the pads and need that special anti-squeal grease? The pads don't come w/ the shims/grease, right?
Normally, you re-use all of the hardware unless a worn or missing item is suspected...Fresh anti-squeel goo is a must, however :)
USE FACTORY PADS !
Quality control on aftermarket pads varies greatly, so you never know what your gonna get. That usually equates to noise/vibration or performance issues..perhaps even excessive wear on other brake components (rotors, etc..) :frown: IMO it (OE) is worth the few extra bucks.
Arkansas
I have never had a problem with Toyota pads. I have had mixed results with others. I reuse the hardware, clean it, check it over, add fresh anti-squeal grease, and it all works fine. When indicated, I buy hardware parts as needed. I used to buy a Toyota kit, but about 10 years ago they started selling the pads separate from the hardware. The dealer told me it was because the hardware was still good and they rarely replaced it. The Toyota pads have not squealed, stop well, and I rarely have rotor problems (I don't turn them).
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
