A jerry can (of any flavor) secured in a tight fitting mount that will not let it shift, would probably not get any rocks/pebbles/debris under it, wedged behind it or whateve,r to cause problems. It is when they are loaded in a truck bed or trailer and secured, but not as tightly as they have to be in the rack mounts... that is when the chafing can be an issue.Here you go Mark: Best NATO can spout.
Fair point on the pebble issue; I always check the pad on my can mount before securing one. In 40 years I've never had such a thing happen.
For a couple/few years way back when, we were bringing an M416 with 35 Blitz cans loaded in it on longer group runs, rather than the pair of 55 gallon drums (plus a few cans) that we evolved to. They filled the bed tightly enough that there was very little "securing" needed... if you were to assume that it would never tip...
Thirty five Blitz cans are a PITA BTW.
That was prime territory for pebbles and other crap to find it's way in and down to the bottom and potentially cause problems.
I hate to be "that guy"... but I often am.
I just can not forget refuel stops during the Treks when there were a horde of thirsty Cruisers all waiting for the juice from those 35 cans to supplement whatever they had on board themselves.
I never had as many spouts as I did cans of course, even if there was plenty of manpower for toting and pouring.
I use an old military (?) rigid spout with my NATO cans. About 1" outlet, built-in air vent. Wouldn't want it to flow any faster.
I think you are describing the original Mil Issue NATO can spout. Yep, internally vented and larger diameter than the "unleaded" spouts that can be found everywhere. Not as fast (in my experience) as the old full sized "Blitz" can spouts, but not slow at all. I was just never able to find a replacement in that style for the NATO cans when the one I had got left on the trail after a group refueling circus.
Before I quit caring, I was able to find several aftermarket ones that *looked* identical to the original. Turned out they were not actually vented, and some did not even fit on real NATO cans, only on the cheap knocks they were sold with.
If you have one of those original spouts, you have GOLD. Or... maybe someone is making a new version now that is actually the same as the originals?
Mark...
