- Joined
- Oct 11, 2014
- Threads
- 10
- Messages
- 68
This is the first day I've had a chance to work with the truck since I started the new job. (notice I said work with, cause she works on me as much as I work on her) I put a new heater valve on her and now I have HEAT. Boy do I have heat. The people that said a properly working heater will run you out have obviously been run out. While I was in there, I replaced all the heater hoses. I also changed the oil and serviced multiple grease fittings. I installed a new inside mirror and both outside rear-view mirrors. New rubber on the brake, clutch and gas pedal looks a lot better than the raw steel. New hood latches were also installed. I put in two new sun visors, too. There's more space between the two visors than the visors are long. I could easily put another one between the two with room to spare.
While I was under there, I was witnessing things I've never seen. The way the front wheels are held to the truck for one thing. That's the weirdest thing I've ever seen. Both sides of the front wheel pivot equipment are leaking. I took pictures of both wheel assemblies and the oil pan area. I've posted them here. Please tell me about the steering hubs (if that's what they're called) and the leaks. I have no experience with these.
What maintenance is there to do? Do I need to be concerned with the leaks? I'm getting new wheels and tires this week. I can't wait to see what kind of difference they will make. I'm also planning on replacing the drums with discs on all four corners in the next 60 days. I've done extensive research on disc conversions here and I'm going with JTOutfitters disc conversion kit. Yes I've read all the negative posts about JTO and I've also got my own experience with them and it's been all good. I plan to start a thread and show every step of the conversion when I do this. I did this with a sunroof installation I did on the FJCruiser forum.
So all that being said, tell me about the front wheels. You teach, I learn, forum grows. Thanks, rog
