Thank you!Hose to your brake booster more than likely. Looks like the "L" connection on your booster cracked
Yep it's grounded to the frame right above the elbow and melted right through it. I think that was jury rigged from the previous previous owner.Something weird going on there. I'm thinking you need to check your engine grounds... looks like the choke or throttle cable was sitting under that piece for some reason and got really warm and melted it.
What he said. I found similar problem on a tractor. It was slow to start even with a booster battery and you could smell a burning wire but not find it. Figured out that the ground had failed when I noticed smoke coming off the throttle cable. I bet you will find voltage going across the choke cable if you check it with a multi meter.What he was saying is that you likely have bad ground somewhere and the choke cable ended up completing the ground circuit between the body and engine instead of a ground cable. The excessive current created a lot of heat energy in the choke cable and melted the vacuum port on the booster.
