What is this, and do I need it
Wild Idaho
??? What is this part between the manifold and the Y-pipe (circled) and do I have to have it?
Nuts, picture didn't make it....why, I don't know..
make sure its under 90k and maybe rename it something very simple...did the trick for me the other day and still don't know why it worked...
It's 37Kb and a gif....... I'm missing somethin stupid here......grrrrrr :doh:
Try giving it an odd name. Common names are used and won't load.
O.K., one more time......short odd name it is.
There you are. Can't answer your question, tho......
yes you will in most cases need it. that exhaust manifold for that side does not have provisions for sealing with a donut style seal. The spacer is a heat operated flap which work to warm the engine quickly backpressure through the manifolds, it has the donut seal rim. i cut out all the flaps and open the hole back up to the correct size.
using stock type exhaust, or the y shown you will need to have it, i guess there might be away not to but i havent don it. Going custom exhaust with flat style header flanges you could get away with not using it.
