What is the weakest link in my "hitch motocarrier system" with extension? I have a 4x4labs rear, 12" extension rated at 500lbs, Motocarrier rated at 400lbs and a 280lbs bike. When i carry it short distances or on rough roads i mount the spare tire inside the truck and it mounts very tight to the truck. I strap it also to the labs bumper and have NO movement or bouncing. But i need to carry it 2000 miles of highway and need the spare on the carrier. So i got this extension. This picture is just a mockup so it is not strapped well and does not have proper pins in place. But it will for the trip. I have a solid 3.5" of extra room. I was thinking of moving it 2" closer.
Simplest way is to move the tray 2" closer on the motocarrier. Other way is i could have a shop drill a new hole in the extension 2 or 2.5" forward and shorten the extension. I figure if i shorten the extension then it becomes better supported. Plus i could cut it to the perfect lenght to get it to extend as much as possible into the Labs bumper. What way would you go with it?
