I have two of my front bumper mounting bolts broken off…I need to find out what the size of the non-used third bolt hole is to try ti use that for a temporary fix…any one know?
thanks for the detail...makes a diff....M12x1.25
Possibly for the ultra rare factory option of the shaft driven winch 🤔So...just curious...anyone know why this un used bolt hole is there? What's it for?
FYI, as it turns out...it is not 12mm ...it is also not 10mm (which is the actual bumper mount bolts size)...which are both too big for this hole...8mm is too small as I bought one of those to try...must be 9mm? couldn't get one of those so will have to search onlineM12x1.25
Common sizes used are M8, M10, M12. I don't believe there is an M9. No bolt supplier has M9.FYI, as it turns out...it is not 12mm ...it is also not 10mm (which is the actual bumper mount bolts size)...which are both too big for this hole...8mm is too small as I bought one of those to try...must be 9mm? couldn't get one of those so will have to search online
hmmm...Toyota doesn't mix metric and sae by any chance do they? I guess I gotta go to a dealer and eyeball their parts catalogCommon sizes used are M8, M10, M12. I don't believe there is an M9. No bolt supplier has M9.
How did you determine that it was not what @jonheld listed?hmmm...Toyota doesn't mix metric and sae by any chance do they? I guess I gotta go to a dealer and eyeball their parts catalog
page to find this thing...
hi bilt4me…I went to hardware store and purchased a M12 bolt and it didnt fit…no idea why anyone thinks M12 is the size…but, opinions differ 😎How did you determine that it was not what @jonheld listed?
I happen to know he is correct, but you insist he is not.
Maybe you could go to the partsouq site and find the correct Toyota P/N for that bolt. It won't tell you the thread or size, but you will have a P/N you can order.
Did you get 1.25, 1.5, or 1.75?hi bilt4me…I went to hardware store and purchased a M12 bolt and it didnt fit…no idea why anyone thinks M12 is the size…but, opinions differ 😎
