What is the Factory ID of this
monroe ga
I know that the transmission and transfer case came out of a 1976 Land Cruiser. I would like to know the gear ratio in this set up. Like first gear, and so on... I would also like to know the factory ID of the trans, and t- case. Any help would be great. Thanks.
Here are a few pics of my 4 speed transmission and transfer case.
IMG]http://i230.photobucket.com/albums/ee201/fj40er/fj40-2404.jpg[/IMG]
I will be painting the transmission this week I hope! I think it will look great. I used a pressure washer and some acid. What do yall think?
Thanks. I would love to see pics., of a nice clean transmission and tranfer case.
The one you have is pretty clean compared to most. Any frame-off resto thread will have a nice one. Use the search, Luke.
Put a t-case saver on that while you have it off. Easy and cheap insurance as well.
Later,
Transfer Case Saver Kit Toyota Land Cruiser FJ40 45 55 - JTOutfitters
One of the weakest links in a 1980 down Land Cruiser is the transfer case. The metallurgical process used to make the transfer case was not desgined to handle the years and increase power that many of the upgrades that people do. We have broke numerous case without the saver, so there was need to gusset the case. This plate gussets the most vulnerable part of your case, where the cracks occur. You can install this plate in a matter of minutes. Transfer Case Saver Kit comes with Saver Plate, 5 extended cover bolts, and instructions.
Copied from JT out fitters page.
Here is the transfer case saver available at SOR. I'm not much of a fan of JTO
Transfer Case Saver
The one I have was made by Poser. I do not think he is fabricating them any more.
It's only a few dollars for the T-case saver. I would do it just in case you ever start wheeling it again. Cheap insurance and easy to install.
Later,
your t-case looks great, I just did not won't to paint my t-case. What color did you paint your engine? I would love to see all your pics, of your FJ40.
The t-case was torn down, degreased, baked at 500 degrees, then powder coated xtreme chrome.
After degreasing the block I used Plasti-Kote: Cast Metal to do the block then powder coated most of what bolts on to it...
