What is the correct operating temperature?
does the correct operating temperature of a diesel engine, equal the thermostat opening temperature?
:beer:
I would imagine so and it would only be a few degrees difference anyway.
Different thermos open at between 88-92 (I think) depending on the climate.
Simon, I used to block off the rad in the winter with cardboard to keep the temps up. The Canadian BJ60's and others had a radiator blind from the factory (mine was removed so I could get the A/C to fit).
diesels run inheriantly colder than a gasser and a winter wind block is a good idea.
the thermostate for CDM models is 88C and that is what these engines run at, as Rosco says + or - a bit...
quote]
Do you block the whole front of the rad or just partially? If partially how much of it do you block off?
what i do is run 2 pieces of cardboard just over half the width of the rad opening. this way i could block off the whole rad if i wanted or i could slide one piece over the other for an opening up to 1/2 the rad...
it seems to work well...
yep using the radiator blind. i now see the advantage of the webasto/espar heating systems for the colder parts of Canada, to bring those diesels upto operating temp.
it's -25c at the moment.
:cool:
:cool:
Its proven to be kinder to your engine also. All that expansion from those low temps to operating temp every day must cause a lot of wear.
