what is the best, and easiest way to rust proof a FJ409 frame?
I just discovered these forums about a week ago, and since have been going through all the questions posted in the past( a lot of good advice) anyway I have used POR-15 on the floor and gas tank of my FJ-40, about two years ago, and it worked great, the floor was rusting and the gas tank leaking...now there isn't a sign of rust on the floor, and the gas tank hasn't leaked since. I want to try POR-15 on the frame, but I can't really do a body off restoration as I have to do all my work in the back yard, and I don't have the money or time. What would be the best way to get inside of the box type frame on the FJ40's to clean away rust and prime and paint?
If you can't tear it down, you sand and clean off what you can reach. This isn't the best, that would be a tear down.
I was so close to the point of having the engine out that i just ended up pulling the engine and going that way...going to take me longer to get stuff done but oh well.
something i found at the plumbing supply (NOT HOME DEPOT OR LOWES) was a 3in stiff round wire brush that had a 1/4NPT fitting on it....i bought a smaller brush with twisted wire handle, cut the brush off the smaller one, welded a female 1/4NPT air fitting on the end and screwed the brush on...then i stuff it in the frame and started going back and forth. Deffinitly helped clean out the majority of the frame...then i took a wire brush(like you get at home depot) and cut the handle off and stuff it inside the frame and just worked it back and forth in the corners to get more of the dirt out...it worked out OK....I then used compressed air to blow out the frame rails......then i started cutting all the stuff off the frame i didn't wany anymore like shock towers but thats cause i am doing a SOA so you shouldn't have to do that :D :D
anyway brake cleaner (the purple stuff at Advanced auto) works really well to get grease and oil off of frame parts ect ect...Use that and a wire brush to do the outside of the frame and you should be golden to paint.
absolute best way is to strip the truck, sand blast, and then paint....
good luck with the POR-15...Rustoleum is cheaper and comes in spray cans!
Stew
Rust bullet seemed to work well for a guy who posted here earlier. Do a search and it should show up. I have used it on other things: haven't attacked a frame yet. I like the way it flows and fills the tiny stuff. I think it gets into the corners better than POR.
thanks for the replys, I guess to thourghly clean and paint a FJ40 frame with rust paint, without a pressure washer, air compresser and paint sprayer , takes a lot of patience and perserverance...and a case of cold beer wouldn't hurt. I don't think I'll try to blow a pan gasket and rear seal to do it...not on purpose anyway.
The simplest and most cost effective way is to drain your diffs and refill with some nice 90wt. Take the old 90wt in the bucket, go park overnight in a dirt lot (read environmentally unfriendly) and literally paint the 90wt all over the frame (after being cleaned).
Most people will agree that solvent dipping, sandblasting, followed by hot-dip galvanizing is THE best methed. However, it does require a total disassembly, and is not feasable in your case. The reason Galvanizing is THE best method, is because it is both a physical and chemical barrier. Many pricey paints (POR-15, etc) will have some chemical properties, but they won't be as effective as pure zinc. You can get a zinc paint (Devcon-Z) that when dry is 95% zinc in a paint medium. It is not as tough as other paints, but that doesn't matter because when it gets chipped, and bare steel is exposed, the zinc will oxidize (give up electrons) first, stopping the steel from rusting. Same principle as sacrificial anodes on salt-water boats.
Also, another method; once you strip the inside of the frame (as best as you can), you could take sheets of zinc (I think they are used under the roof-caps when you build a cedar shake roof) and cut thin ribbons off with tin-snips. Wrap the ribbon into a spiral (like a slinky) inside the frame rails so it touches all the inside surfaces. Paint the inside of the frame rail and you will have both a physical and chemical barrier.
good luck,
Steve
Plus the smell of gear oil in the cab will get rid of any "old car smell" your cruiser might have and make obsolete that little green tree thing haning from your rear view mirror :D
putting the old oil on the frame would probally be the easiest way to rust proof it. I went to the Rust Bullet website, and read about Rust Bullet, seems to be easier to use than POR -15, and I have read posts on this fourm saying it is great stuff. I have never heard of coiling up a piece of zinc like a slinky and putting it inside the frame...how is that supposed to keep the frame from rusting...Thanks for the replies...CRUISER NUT
