What is my axle ratio??
Wasilla/Bangkok
I have acquired a set of axles from 1990 LH78.
I checked the ratio by marking the tire and rotating the tire one revolution while counting the number of times the pinion turns.
For one revolution I get 2.2 revolutions on the pinion, works out the same front and rear.
Is this possible? I thought the stock ratio for these axles was 4.88!
Is there such a thing as 2.2 ring an pinion?
I figure I must be doing something wrong, but I cant figure out what.
If your diff was "locked" (so both wheels rotate together) you'd get the right ratio. (The spider gears are "messing it up for you".)
Assuming you're not locked, with one tire in the air you spin it TWICE and driveshaft revolutions = ratio. You spun it once so 2.2 x 2 = 4.4 which is pretty close. You've probably got 4.88.
Butt
