what is death wobble
Discussion in 'Chit-Chat' started by concretejungle, Aug 16, 2005.
  1. concretejungle
    concretejungle SILVER Star
    9,517
    743
    Oct 27, 2003
    North Cadillac
    Had a local kid with a jacked-up jeep ask me if i am having any problems with death wobble? WTF? never even heard of that. He said he can't go over 35mph without almost losing control of his rig. What is death wobble? I have heard of it when i was a kid screaming down the street on skateboards, but not vehicles.
  2. 2badfjs
    2badfjs
    5,522
    3
    Jan 26, 2005
    in the garage
    same as a skateboard,but in the front end.
    feels like everything is coming apart.
    could be tire balance,trunion bearings,tre's
  3. mabrodis
    mabrodis
    1,150
    4
    Mar 22, 2004
    Castle Rock, CO
    I don't know the technical definition of it, but it's when the vehicle's suspension and steering are somewhat at odds with each other. So the suspension moves pushes the steering one way, then the steering equipment fights back and pushes the suspension. It usually happens on vehicles where the steering and suspension have been modified, so the steering is at an angle where more bumpsteer can happen, larger tires can be more out of balance and can trigger it. When death wobble (DW) kicks in, usually there is nothing that can be done, you just have to slow, sometimes to a dead stop, then start out again. It basically is a visious cycle between the suspension and steering, and you can't break that cycle until you slow way down or stop.
    Do some searches in the 40 and 60 forums, you'll see writeups on it, it definetly can happen, my 40 had it horribly bad, for me it was all tires (that triggered it, having modified suspension and steering doesn't help the situation though)...some say loose knuckles and TREs can trigger it, but I've never seen those play any part at all in it, and I've seen 40's with 30 yr old TREs and knuckles horribly worn, and they had no symptoms of DW whatsoever.
    Many jxxps get DW (solid axle, more bump steer when lifting, etc), I have several friends that fight it on a week by week basis to minimize it.
  4. woody
    woody unhelpful spotter Staff Member Admin
    10,745
    Media:
    317
    Albums:
    8
    2,366
    Jan 15, 2002
    Toquerville UT
    death wobble is caused by a pile of things.....loose wheel bearings, unbalanced tires, bad tie rods, bad spring bushings, loose u-bolts, bad kingpin/trunion bearings, too light of preload settings on bearings, and a host of others....
    the description is right on....driving down the road, hit a certain speed, and the front tires suddenly vibrate back-forth, WAY beyond what your hands can control....you can either A> attempt to drive thru it, usually a 15mph speed increase will ditch it, or B> come to a stop/near stop, and then do NOT approach the death wobble speed again.
    Driving thru is dangerous, since having the power to accellerate quickly thru that wobble isn't always possible....the wobble can either start "on its own" or can be jump-started by crossing a bumpy road section like railroad tracks or a bridge.
    The cure is time consuming, and consists of major maintenance and adjustment of ALL front axle related items, steering, tie rods, toe settings, tire balance/pressure, torque settings, etc....
  5. dmc
    dmc
    684
    Media:
    5
    Albums:
    1
    281
    Apr 6, 2004
    Wandering the Western Hemisphere
    My 40 had it bad. Even broke a front spring hanger because of it. I tried everything, bearings, TRE, tires, pitman arm etc. Nothing fixed it. Final solution? Ditched that damn old coarse spline axle and upgraded to a disc brake front. It magically disappeared. I don't even run a stablizer now.
    dmc
  6. Greg_B
    Greg_B
    4,434
    134
    Mar 28, 2002
    And even all of that and more does not work sometimes. The only thing that solved mine was a steering damper from axle to tie rod. Relay rod to frame did nothing...
    gb
  7. mabrodis
    mabrodis
    1,150
    4
    Mar 22, 2004
    Castle Rock, CO
    The only thing that cured mine was rebalancing tires, rebuilt entire frontend, everything was tight...still would DW horribly bad...but wasn't consistent, would be ok then when hit a bump wrong...eeek...hang on!
  8. zetasig
    zetasig
    1,419
    Dec 4, 2002
    Hiding
    I have also heard it called bump steer. I think meaning the bump starts steering the vehilce where you dont really want it to go.
  9. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,060
    531
    Dec 13, 2002
    Knee deep in hookers and gin
    Bump steer is different. Bump steer is when you hit a bump and the steering reacts. Pretty common in primitive steering linkages. Worse if your geometry is off.
    Death wobble is an oscilation that gets worse. The whole damn truck shakes back and forth.
