New guy here - both to this forum and to FJ40's in general - so apologies in advance if this is a naive question. I recently inherited a 1976 FJ40, and I'm experiencing some inconsistent overheating issues that I'd love to get some guidance on. For reference, my temp gauge has two lines - one at the ~1/3 mark, and one at the ~2/3 mark (I'm guessing this sounds familiar to most of you). Anyway, since acquiring it, I've been making mostly short trips (<10 miles), and it was doing fine for the first few weeks. Then I took it on a longer drive (surface roads, averaging 40 mph), and I watched the temp gauge steadily climb until it hit the 2/3 line after about 20 miles, at which point I pulled over to let it cool down (coolant was spewing out of the overflow tank at that point). I decided to bring it to a mechanic that I trust about 30 miles away to have a look. Strangely, I didn't experience anything close to overheating on my drive to the mechanic (the needle hung out at about the halfway point for the entire drive), and my mechanic couldn't replicate the overheating issue during his test drives or extended idling either. Nevertheless, he recommended flushing the coolant and installing a new thermostat and radiator cap, which I had him do, hoping that would solve the problem. Unfortunately, on my drive home from the mechanic (same roads, same speeds, even the same weather), the engine overheated again, and I had to pull over twice to let it cool down on my drive home. To be clear, I've not let the temp gauge go much above the 2/3 line, for fear of causing damage to the engine.
Any thoughts on what might be causing this? The fact that the overheating seems to be inconsistent is what is particularly confusing to me. I don't know how long the vehicle was sitting before I acquired it, but it had a relatively recent sticker when I got it, and passed inspection without problem this spring, so my friend didn't let it fossilize. Based on my limited research, I'm starting to wonder if the radiator needs to be recored...however, if coolant is not moving efficiently through the radiator, I would expect the engine to overheat in a predictable and repeatable way, rather than seemingly randomly. But I don't know much about this stuff.
Thanks for any thoughts you folks may have.
