This past weekend, got her fired up for the first time in a year. Still a good ways from being able to drive her anywhere but I was stoked to hear the engine run. Thanks to Mark A. for the carb rebuild, to Kurt at Cruiser Outfitters for the axle parts, to Upstate Cruisers - esp. Chuck and Marshall aka Trollhole for spare parts and general info. Just need to save up a little money to get an accelerator and throttle cable from Mark A. and redo the drain plug for the T case. Pics will be forthcoming when I take to the streets.
One final problem which could be big - stripped drain plug for the t-case. Tried to put in 3/4 inch self tapping plug but just stripped it out - should've drilled the hole bigger first but I didn't. Now need to try the helicoil route.
Question - Assume the hole is closer to 3/4 inch now - what helicoil package do I want in order to put the original plug in? Or do I now need to drill the hole bigger to put in a helicoil for the 3/4 inch drain plug? Can anyone direct me to a part number or a company that I can call? Thank you!! The lady at NAPA did not seem to know.
William
William
