Greased my u-joints & driveshafts, then pulled the running boards off!
After my AHC collapsed, I did a AHC to conventional suspension conversion. Why I didn't repair the AHC?
The only thing that had been changed on the AHC in 23 years was the 4 corner globes. Everything else seem to be original. Some of the actuators have started to sweat oil. Error "abnormal pressure at the pump" could be the pump itself or the central accumulator, or something else. I wanted to source this parts from amayama, but they classified the parts as dangerous goods and wouldn't ship them overseas. Getting them from dealership here in Costa Rica was very expensive. I found companies on ebay willing to ship them, but didn't really trust them. And finally, if I had done it, all other parts are still old and can brake at any moment. Also the central accumulator is a pane in the butt to reach the upper screws. Since this is my daly driver on which i depend, I choose reliability over AHC. I let all the AHC components in place, in case I change my mind later.
I was advised by an experienced Aussie to go with Toyota original suspension parts, since this gives the best ride quality. And so I did. I did not lift the vehicle since I do not extreme off-roading. However i put slightly longer springs in, to compensate for heavy load i carry on a regular bases.
I also changed al the bushings on the rear suspension. I had not the right tools for the front suspension, so i have to do it later. It was the first time i did such a job, so it took me some more time to prepare and run away for some tools etc. But if you are experienced and have a lift available, you can probably do it much faster.
What you need:
  1. NON AHC torsion bars (left and right are different)
  2. 2 x Front Shocks (left and right are the same)
  3. Front Retainers (washers) they are different from the ones used in AHC setup.
  4. Rear springs (check your exact configuration, on mine the LHD is a little longer to compensate for driver and fuel etc.)
  5. 2 x Rear Shocks (left and right are the same)
  6. Rear Retainers (washers) again different from AHC setup.
  7. 2 x Spring Hollow, rear
  8. 2 x top and bottom spring insulator.
  9. Bushings and parts you want to replace independent from AHC conversion.
  10. Rear Sway/Stabilizer bar, Toyota has a different number for AHC and NON-AHC, but in my case they were exactly the same. So I changed it probably for nothing.
Work to be done:
Put car on stands and make sure its save and stable. Remove AHC hydraulic fluid from reservoir at the pump. depressurize the 4 globes and the central accumulator. Remove the wheels. Unscrew the torsion bar adjustment bolts. Loosen the 2 nuts of each hydraulic line on top of the actuators (shocks). Put a floor jack underneath the rear axle for support before loosening the top nut on the top of the shocks. This top nuts are a little of a pain because of missing space, but it is possible. Once both shocks are out, you can lower the floor jack as much as possible, without damaging lines and cables. The old springs will go out easy and then new ones will also go in easy. Since the non AHC springs are much stiffer then the AHC springs, I had to load quite a bit of weight into the car, so i could compress the new springs sufficiently without lifting the whole car with the floor jack. So i could insert the new shocks. Thankfully I had about 30 boxes of beer laying around :beer:
That's basically it for the rear.
For the front, take the the torsion bars out first. there is more space for the top nut at the shocks, so its easier. Then Put the new shocks in. Now put the new torsion bars in and adjust the height. That's basically it.
Good Luck
Been slowly getting the wife's LX tuned up. Rebuilt the control arms off another truck with some fresh bushings and replicated the OEM paint markings for extra HP. New rear brakes and all new sway bar bushings and hardware. Threw in land cruiser AHC rear coils too.
Tuned out the AHC and got all in spec. Of course then I find error code for melted AHC wires near muffler. And both rear calipers have stuck bleeder valves. Always 2 steps forward one back!
Truck drives way nicer, especially with recent new globes and AHC flush. Next up new muffler (leaky one is what melted my wires), some wire repair and then moving to the front end.
Replaced the headlights with OEM glass assemblies and the corners with DEPO clear assemblies.
Old:
New:
I actually have a crisp cutoff now at night. Unfortunately Texas has too much light pollution, so the warm light blends in with the surroundings while driving in well-lit areas. It's a definite improvement though! I can always upgrade to HIDs down the line.
Do you have the part numbers for the OEM glass headlights? TIA
These are for the pre-facelift models, so 1998-2002 I believe, you'll wanna verify that they fit before you buy them. The facelift models use polycarbonate instead of glass.
Headlamp Assembly Right Hand With Clearance, Part Number: 81010-60072
Headlamp Assembly Left Hand With Clearance, Part Number: 81050-60072
To the best of my knowledge…
2002 and earlier have glass headlight lens
2003-2005 have multi-piece polycarbonate lens
2006-2007 have one piece polycarbonate lens
On the trip down to Arizona we drove through some heavy rain. When I unpacked I noticed the tailgate carpet was wet. My first thought after doing some research on MUD was the third brake light. I pulled it off this morning, cleaned it up and used a headlight kit on it and put it back on with butyl tape. It does look to me like that's where things were leaking. It was grimy and wet under there. Unfortunately it also looks like an aftermarket unit. It does work though and now looks better. It sits a bit proud with the butyl tape, but hopefully it won't leak anymore.
I like windoweld by 3M for this instead of tape. Crazy sticky.
Decided today was the day to diagnose and fix my inoperable left high beam. Set aside some time and patience in preparation for a miserable wiring wild goose chase. I chase down some diagrams and pop the hood. Check the fuse box. Someone took out the LH high beam fuse. What a dumb thing to have procrastinated. Then proceeded to wire my spotlights so I can use them with my high beams on the column. I’ll take the wins where I can get them.
procrastinated
This was me last year, couldn't figure out why my light output was so low on the driver-side low beam. Finally got around to it in January - previous owner improperly screwed the light bulb into the housing so it  looked lit up but was about as functional as a candle.
Anyway, how'd you wire the spotlight to the high beams?
I can’t be that guy. When the road is empty I just run the spotties as high beams.
Honestly the OEM High Beams are plenty for me, even in brightly-lit Texas. Daniel Sterns knows his stuff.
Hikari LED
Tried it. Ran Sealights first, then Diode Dynamics, all LEDs; all got returned. The housings just aren't made for LEDs, plain and simple.
My spots pull power directly off the battery with a relay. The old setup was a permanent hot off 12v with a switch in the truck hooked up the to coil side of the relay. I just moved the permanent hot 12v wire to the driver side high beams bulb power. It’s a 20amp circuit so I figured the 100mA draw would be insignificant. I originally wanted to wire it up in line with the stalk but couldn’t figure out the pinout on the stalk plug, but it works really well. I just can’t use my spotlights without my high beams, which seems like a useless configuration anyway, and a worthy sacrifice for being able to switch them on and off just like my normal highs. Also, I can leave the switch on and flash modern super duties and 3/4 tons with their f-off illegal high beams with a single pull back on the headlight stalk.
