WHAT GEARS w/ 37's?
NE Indiana
Howdy All,
I currently have 35's and running 4.10's. I am moving up to 37's and was wondering if I'm OK to keep my 4.10's or should I bump up to 4.88's? I will be putting ARB air lockers in front and rear before the tires. If lower gears is recomended, now would be the time instead of digging in there twice.
Any thoughts?
It would be fine to keep your 4.10's, esp with your transmission. I have 37's, 4.10's and a higher first gear than you. I would like to be lower geared, but only for crawling--its fine for the trails around here. I'm planning on 5.29's when I regear, but with no overdrive, you may not want this option.
If you want the same overall gear ratio:
37/35*4.10 = 4.33. With 4.88's, you'll end up lower geared than you are now.
If you drive your rig long distances, I'd plan on leaving it alone and only change it if it really bothers you.
I'm in agreement with Senor Aguas relative to your V8 pushing your 37's down the highway just fine. I suspect I would still want some lower gears for:
(a) off road use
(b) better punch off the line
(c) probably better milage. It takes alot of throttle pedal to get a 37" tire rolling with 4.10 gears?????
Thanks for the input. I have more concern with off road than highway. I'm usually not in any rush on the highway and don't push it when driving a cruiser. That said, I'm leaning towards a lower gear.
I am perfectly happy with 4:10s, a 2F, and 36 Iroks on the hwy. I have to drive anywhere from 3 to 10 hours to get to the trail. I have a ToyBox for the slow. If the SM465 is not slow enough you could add an Orion behind it to slow things down more.
Match your gears with your tires. regardeless of your engine
4.88s with 37s
no question.
One of my rigs is minitruck w/350
I took the attitude that I did not need gears for 36s with the power that I had... and it did fine... on and off road.
but when I moved to 4.88s I re-learned this lesson... which I should have needed no reminder of.
It was a different rig. So much more crawl... so much more screaming on the road pep... and not enough loss in 5th gear to care.
Done the same thing in 40s and 60 series... big tires before big gears. Always MUCH happier after the gears are added.
Match your gears to your ties... do not think that a powerful motor negates this need.
You want 4.88s with 37s.
Mark...
4.88s with 37s
no question.
Mark...
Couldnt argree more! Ya... you can run the stock gears and it will be managable, but then later on down the road when you decide to put the correct gears in- you will wonder how you ever made due with the stockers. HUGE DIFFERENCE! And especially since you gonna be in there for the ARB's anyway!
The one big plus to keeping the stock gears is finding a spare diff on wheeling trips and events should you blow up a diff.
This is a fairly true statement, but the lower gearing of the 4.88's will mean less need to hammer it over stuff where springs wrap and pinions break. I broke a pinion while running 4.10's and easily found a spare 3rd member, and wheeled the next day. Had I been running 4.88's I wouldn't have needed as much pedal on that obsticle, and would not have wrapped the springs as such. since I changed to 4.88's there have been things I have had to bump the trhottle to get over but not as frequently as with 4.10's or nearly as hard on the throttle either.
i agree.. 4.10s are more common and someone will more than likely have parts to help out if needed. but 4.88s are getting more popular than before, so you may what to go that route. and get some spare part while your at it in case some one need it. j/k
i got 4.88s cause my 4.10 were heavily pitted from rust and needed to be replaced. so i took it as a upgrade when i wanted to get lockers.
Thanks for all the good input. So here is what I take away in short...could get by fine with 4:10's but 4:88 would be a nice upgrade for various reasons. I'm already in there for the lockers so 4:88's it will be. I don't have the tires yet so this will push me to get the 37's and practice for my first attempt at body trimming!!
You can't make a wrong decision here. I upgraded to 4.88's on my FZJ80 when I went to 35's and never regretted it. I'm just saying that you probably won't hate the 4.10's with 37's.
If you're set on changing the gears, I'd take a look at the rpm differences between 4.10's, 4.88's and 5.29's and weigh that against how much you drive on the interstate. If you never get over 55-60 mph, I'd go 5.29's.
With 37's, 4.10's at 60 mph, you'll be turning 2234 rpm
Change to 4.88's = 2660 rpm
Change to 5.29's = 2882 rpm
4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
David.
Guys,
Reading this post reminded me of a conversation that I had with the folks who make the Orion xcase. I was really trying to figure out my options if I should upgrade to the H55f 5spd. As I understood it you really have a choice when running bigger tires on a mixed use rig (60% highway, 40% trail in my case). I could get the 5spd and go with 35s but to get better crawl I would really need to go with the 4.88 gear set. However in doing so I'd be undercutting the purpose of getting the 5spd, lower RPMs at highway speeds. The other way to go would be to keep the 4.11s and 35s in combination with the 5spd and get the benefit of lower RPMs and swap out the transfer case for an Orion to get the lower crawl while on the trail. Did I get that right? The choice is a compromise:
run 35s and 4.11s and a 5spd, gain lower RPMs on highway, lose some crawl on the trail
run 35s and 4.88s and a 5spd, lose by getting higher RPMS on highway, gain crawl on the trail.
The Orion would get you a compromise, keep the stock 4.11 gears, run bigger rubber 35-37, keep lower RPMs but actually gain crawl on the trail due to the Orion's gearing. Is that about right?
4.88s with 37s
no question.
Mark...
Good call! I'm running that exact set up (SBC, SM 465, 37's, ARBS, 4.88 gears), and I couldn't be happier. You'll be glad you did it. Also, FWIW, I didn't need to do any trimming and I'm running 1.5" spacers on each corner. You'll love it. :cheers:
Part of the reason I thought I might have to do some trimming with the 37's is that my rear springs are flipped, moving the rear axle back.
Also, dumb question (at least it feels dumb)....explain what the 1.5" spacer is.
Possibly, with the flipped springs. The spacer fits on the rear studs and is 1.5" wide. Effectively widens the stance by 3". :cheers:
I kinda thought that but didn't realize you could get spacers that thick. I assume the reason for that is either stability or wheel backspacing?
Not to Bring another Variable into the mix, but the deeper the gear set the weaker the 3rd member..
some of the yota guys ive wheeled with have ok luck with 4:88's, but most stick with the 4:11's and use crawler boxes and lower T-case gears for crawling..
Id love to have 5:29's for on the road. its all a trade off..
