what do you guys use to vent your toyota diffs, 5/16's fuel line to a filter?
I linked everything(diffs, cases, tranny) all to one fuel filter mounted up high by the brake booster, out of the way of water.
Manny-
there was a thread a little while back about this, and one cool set up is the atv tank breathers. They are an accordian style tube.
My current set up- I just popped the cap off the vent and used fuel line. I had found some caps that plug into vent lines like that come on the axle, but plug into hose- on a heep cherokee- early '80's kind. I run that hose as high up in the engine compartment as I can. Has worked well for years.
cheers-
Dustin
I used the accordian boots, $5-less each. quick search in hardcore outta find the source for ya.
ended up removing the stock fitting, tapping for pipe thread, and using that....buy spare boots in case you tear one tho, I bought 5 and it was like $22 delivered for all.
How many vents are there? I know the two axles and transfercase. Is there one for the transmission or something else as well?
use silicone tubing. Will hold up much better in the long run since it will stay soft and doesnt have plasticizers in it!
