What do we know about pavers...
Discussion in 'Chit-Chat' started by fsusteve, Aug 17, 2006.
  1. fsusteve
    fsusteve
    3,803
    Media:
    18
    Albums:
    1
    52
    Aug 2, 2003
    Naples/Big Pine Key, Fl
    cause I got about 800 sq ft going in this week. Some guys I work with have a paver company here and do very good work. My question is, just in case the workers are ever unattended, what are some things that are a must when installing them. I work on the trust but verify school of thought.
    Doug, Cookie, WS, whatcha got?
  2. greytandy
    greytandy
    1,660
    Media:
    13
    Albums:
    1
    1
    May 14, 2006
    MD 'Burbs of DC
    Depending on how you do it, a rubber mallet, a long level, a brick saw, and knee pads. I made my own 250 sq. ft. patio a few years ago. It was alot of work.
    EDIT: This assumes you already have a level base of sand or crushed rock to work from.
  3. TX_TLC
    TX_TLC
    1,480
    9
    Apr 29, 2003
    Texas
    A well prepared base is a must! Here they dig out about 12-18 inches and build it up from there. Crushed limestone compacted down then sand to level it out. Once placed a top application of sand forced into the joints to lock it all together and you should be good for many years to come.
  4. fsusteve
    fsusteve
    3,803
    Media:
    18
    Albums:
    1
    52
    Aug 2, 2003
    The baserock is already in, initially I was doing a deck, but cost wise this was much cheaper. The sand should be here today, pavers tomorrow. They'll concrete in the edges except where there will be a small stone retaining wall going in. I know a little about it, but just want to make sure about compaction and the sand process...
  5. nicksfj-40
    nicksfj-40
    300
    4
    Apr 11, 2006
    Tulsa, Oklahoma
    I used to install pavers. We would make a 6 to 8 inch compacted base. Level the sand, lay pavers, compact with a walk behind plate compactor. Be careful around the edges. Put a concrete "toe" around the perimeter. Throw out sand and re compact with compactor then you are done. That job sucked. Lots of work.
  6. White Shark
    White Shark
    763
    Media:
    1
    Albums:
    1
    3
    Dec 13, 2004
    Red Triangle
    Using a wacker, or even better, a vibratory plate compactor, will pack your base properly. Don't soak it to get it to pack down, as the water only takes up space which will be loft over when it dries out. Compact the base or sand dry.
    Having a concrete saw to cut the pavers is a lot cleaner than using a hammer and chisel, or a brick cutter.
    Setting the grade can be accomplished using a line level, water level, or even better a laser level and grade rod. You can also use a grade rod with a transit to get the proper grade.
    Using a good border edge will keep things in place and prevent the base from pusing out when the blocks are set. A lot of guys put down a good weed block material down before the base to allow water penetration, but reduce plants from pushing up between the pavers. The sand or base will still allow some weed growth, but Roundup will keep that under control through a 2-3 times a year spray application.
    Spread the base with a landscape rake, compact, and invest in a good set of kneepads. ;)
    Pretty much what everyone else has said too....
  7. 45Kevin
    45Kevin
    2,301
    738
    May 10, 2005
    Calgary, Alberta
    I have seen the sand leveled with 1" electrical conduit. Lay two lenghts parallel about 8-10' apart and use a screed or straight 2x4 to get a level suface. Pull up the conduit and fill in the line as you lay the pavers. I have not tried this myself but it produced a very nice result for my neighbour.
  8. rusty_tlc
    rusty_tlc Dain Bramaged Member
    13,411
    Media:
    3
    Albums:
    2
    917
    Jun 23, 2005
    Reno, NV
    2 year paver patio owner here.
    The sealer is crap. Lasted about half way through the first year then the ants plowed through it.
    I have a product called sand lock that I plan to try as soon as I have time to power wash the sand out and re-do it. Fawking PITA:mad: . wish I had gone with stamped concrete instead. I loved the concrete patio at my old house, 15 years and no maintainence. Price wise it was a draw between the two when we did this house. We thought the pavers would look nicer but that was a mistake.
    Call it off if you have time.
  9. UltraFJ40
    UltraFJ40 ที่นี่และมี SILVER Star
    2,028
    14,988
    Sep 1, 2003
    Dito loob ng kubo kubo ko
    Sorry I just found this thread Steve. I was wondering the same thing as I am clueless about them.
    Whats the cost and maintenance of concrete vs Pavers? (Doing my front entry soon, currently have that 70's brown pebblerock [​IMG])
  10. Conex
    Conex
    157
    1
    Dec 25, 2005
    Bradenton, FL
    If this area will be getting a lot of water on it, plan on regularly buying sand and using a push broom to keep the pavers from moving when the joints wash out. Otherwise I think they look good.
    There is a resort here that did all of thier roads with pavers (about 10 miles). They have a full time crew of at least 10 guys pushing sand down the street with brooms.
  11. nicksfj-40
    nicksfj-40
    300
    4
    Apr 11, 2006
    Tulsa, Oklahoma
    If you do your compaction right, and run your grades right, and make your border out of a concrete toe, you shouldn't have to worry about the sand washing out. Maybe twice a year throw more sand down. I have put in city roads here in downtown Tulsa that look just as good now as the day we installed them. You have to know what you are doing to make them work. Also that post above about using electrical conduit to run your grade is the way to go. You can also set all your grade with string line...not all that fancy laser crap.
  12. NorCalDoug
    NorCalDoug problems solved daily...
    6,293
    115
    Oct 27, 2003
    uhhhh...duh...Northern CA
    I had some input...really I did...but it's not any better than what whiteshark, nicksfj40 and others have already posted.
    get all the prep work done right and the rest will all fall right into place. laying pavers is really pretty easy.
  13. White Shark
    White Shark
    763
    Media:
    1
    Albums:
    1
    3
    Dec 13, 2004
    Red Triangle
    Occupational hazard. When you already own a self levelling laser, tripod, and grade rod, it's the way to go. Otherwise, use what you've already got. :cheers:
  14. fsusteve
    fsusteve
    3,803
    Media:
    18
    Albums:
    1
    52
    Aug 2, 2003
    The paver's are going for around $4 a ft. Concrete was about the same, if you include labor on both. I had planned on a deck, but it was running about $1800 more with me swinging the hammer. The guys doing it work for ENFD (Palermo Pavers) and are really good guys, give me a call if you want me to send them your way....
    404-4607.
    Like rusty said there will be a little more maintenance and I do love concrete, but I think the pavers will be cosmetically more appropriate out back. How's retirement?
  15. TJDIV
    TJDIV Back in The U.P.
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    call eric. he'll come down and pack your base.
  16. fsusteve
    fsusteve
    3,803
    Media:
    18
    Albums:
    1
    52
    Aug 2, 2003
    he's gotta catch me first and I'm one fast mofo....
  17. NorCalDoug
    6,293
    115
    Oct 27, 2003
    what do you think the pooches are for...
    :flipoff2:
  18. fsusteve
    fsusteve
    3,803
    Media:
    18
    Albums:
    1
    52
    Aug 2, 2003
    Ok, I'm a fast mofo that can shoot on the run....
  19. White Shark
    White Shark
    763
    Media:
    1
    Albums:
    1
    3
    Dec 13, 2004
    Red Triangle
    What type of fudge are you using for base? Just wondering... ;)
  20. Cruisin'Carolina
    Cruisin'Carolina
    1,435
    9
    Dec 11, 2004
    The Rock
    You must have gained some weight;)
