Replaced the electric motor for the rear upper lift gate lock also replaced the outside handle on the rear upper lift gate.
Check Your Nuts
Thought this was a good share.
17mm offset wrench Capri #CP11950-1719
Is the coax to the GMRS antenna compatible/ the same as the CB antenna? I'd like to change over but don't want to rewire the whole setup if I can avoid it.ditched my CB for a GMRS and never been happier...
I need those, thanks for the tipI love offset box end wrenches. I carry the 17/19, a 14/16, and a 10/12. I use them on the cruiser all the time.
No they are not. Not having to ground the antenna and having to mess with tuning and crystal clear reception does it for me...Is the coax to the GMRS antenna compatible/ the same as the CB antenna? I'd like to change over but don't want to rewire the whole setup if I can avoid it.
Are you sure about this? I thought both use 50 ohm coax. I know that the antennas are different but haven’t seen anything online indicating that they require different coax.No they are not. Not having to ground the antenna and having to mess with tuning and crystal clear reception does it for me...
the cable itself should be fine, but you probably have the wrong antenna-side termination. GMRS antenna's typically use NMO.Is the coax to the GMRS antenna compatible/ the same as the CB antenna? I'd like to change over but don't want to rewire the whole setup if I can avoid it.
Yeah I'm probably going to get a stock rear bumper now. The front is as stockish as they come. TJM T17...Love it, but some stock (or other less-bulky) bumpers would really compliment the de-flared look.
He has been on mud here briefly on a hyper arm thread that turned into a 4" lift thread kinda... I like the bumper & different paint color usage. Hope he chimes in.
Does this fridge charge and then you throw it in your rig and it keeps stuff cold for a few days without any 12v connection?
That would be cool, is there such a thing as a battery operated frig???Does this fridge charge and then you throw it in your rig and it keeps stuff cold for a few days without any 12v connection?
I looked the part number up: Google will translate it.
Автохолодильник Libhof Q30
Добавил немного комфорта в поездках. Холодильник — один из самых важных аксессуаров для комфорта в поездках. Прям как хороший спальник, без которого ездить можно, но что-то не то, чего-то не хватает.…www-drive2-com.translate.goog
It’s a vehicle spec 12/24V fridge.Does this fridge charge and then you throw it in your rig and it keeps stuff cold for a few days without any 12v connection?
Sorry about that, looks like they do not. But I did run across several manufacturers that do provide that, while I was shopping for my current iceco fridge....ICECO has one.
