What Did You Do with Your 80 This Weekend? (64 Viewers)
Whoever had a bumber coming from dvs that had a boo boo and cancelled, sorry to hear it. But your bumpers coming to a good home.
Clear corners are not NLA, I got mine off Partsouq within the last year. You just need to search all the oddball non US models and years. The crappy options on Ebay will last you a couple years and fade quickly.
Clear corners are available thru multiple vendors. LX specific are not. Been looking for a bit, no luck.
Which numbers? I looked at all the references I have.
part number 8162160063 / 8161160083 used here ordered 6-3-21
showing out on partsouq now but see them here: * at nearly twice the price now...
Yeah, your out of luck but I would still go OEM clear over anything else off Ebay, unless used OEM.
Engine out now time to clean clean clean!!!! Couple pro tips.
Pull transmission mount isolator it’s the lowest point.
Disconnect t case shifter and set to the side it’s the highest point.
Drink beer!
Take hood off before you start pulling the motor:bang:.
Drain coolant from block not just radiator hoses!
Drink whiskey!
Pull front sway bar as it’s easy and in the way.
Have a helper it would have taken half the time with just someone jockeying the hoist around.
True dat. OEM all day.
I almost wanna buy a set for back up.
Do those have "DOT" molded in the lens? I kinda doubt it but I'm curious.
Tacked up a hilift mount for my Avid rear bumper this afternoon. Sits tight to the vehicle, but some protective rubber ought to do the trick :)
Also went and visited my new motor yesterday
New o2 sensors, gotta buy new nuts the old ones crumbled when I pulled them.
In case any of y'all lurking get the inkling to buy a cheap 80. Broke the 10k mark today. Still need to do brakes, trans/diff fluids, weathertechs, KO2s (with bronze SCS F5s if I can't control myself), oil pump gasket when I feel like it, and some bushings, and I'll call it "done". I can see the light at the end of the tunnel.
View attachment 3000542View attachment 3000547View attachment 3000543
Have you done trunnions and wheel bearings yet? Really adds up. Also check the rear quarter glass seals. They tear when they get old and let moisture into the quarter panel.
