- Thread starter
- #41
Finally installed my matching rear door. Found it on Craigslist about a year ago.
Nice garage setup!Finally installed my matching rear door. Found it on Craigslist about a year ago.
I did close it up, but it’s pretty easy. Currently my brake is set just about right. When I do my next oil change I will rotate tires and inspect my rear e-brake shoes.If you haven’t closed up the console yet, it would be a great time to check / ajust the e- brake cables.
Cool. What did the floppy one look like when you pulled it?Replaced the floppy shifter with a used one in great shape. No more slop & flop:
I can upload a video to YouTube and link here.Cool. What did the floppy one look like when you pulled it?
Can't remember if either assembly comes with the retaining bolts, but you'll want to replace them as well, as they are considered single-use. You'll need one for each spline section coupler.Fred Anderson Toyota sent an email announcing 25% Off Toyota parts until end of January. And because I need to replace my intermediate steering shaft, and possibly the lower steering column assembly, I ordered both. My FJ for most of its life has had a knocking sound in the column especially off road when the front wheels are being kicked back and forth. I’m determined to fix that.View attachment 4073079
I searched both of those numbers and neither come up.Can't remember if either assembly comes with the retaining bolts, but you'll want to replace them as well, as they are considered single-use. You'll need one for each spline section coupler.
Part number:90119-0856090080-11555
That’s not the place to adjust parking brakes, the cables don’t stretch. There is star wheel inside the drum where to adjust.If you haven’t closed up the console yet, it would be a great time to check / ajust the e- brake cables.
Yes I’ve heard to adjust them at both ends if necessary.Really? So why are the cable ends threaded at the equalizer? Back them off, ajust the shoe to drum clearance, then ajust the cables for the desired number of “clicks” at the handle.
The main thing is that you are not doing the whole adjustent only by tightening the cables.Really? So why are the cable ends threaded at the equalizer? Back them off, ajust the shoe to drum clearance, then ajust the cables for the desired number of “clicks” at the handle.
I hate this e-brake design. Mine would never hold adjustment and became worthless after a week of driving. I pulled the shoes and actuating hardware after doing my rear wheel bearings the first time. Later I pulled the cables from the dust shield and zip tied them to the top of my slider supports. It makes doing rear axle work a lot easier without the cables tethered to the hub assemblies. I contemplated repurposing the cables to actuate a driveshaft mounted disc brake. Maybe I'll eventually go there.
