This was a while back while I was trying to remove the door sidings to access the door speaker. Ebay to the rescue $$$
Yikes, that could have been really bad.Definitely posting here too often, but I had another failure I didn't expect.
Last night I was driving home from wrenching on another Land Cruiser 100. On my way back I was driving, let's say 125+km/h/75+mph and then my upper balljoint snapped on the highway.
Bit of careful steering and sliding later I was on the Shoulder and saw this:
Got a flatbed tow home and saw what happened, balljoint does not have any play but snapped where the ball meets the pin:
And another picture:
I've got a 2'' Ironman Foamcell Pro lift, the ball joints do not bind but I do really use the HDJ100 off road.
Upper control arms and upper balljoints were cheap units
Put some old OEM ones on for now and will probably order a new set of OEM UCA's of aftermarked caster corrected ones.
Are these "cheap units" made in China jobs? To snap at the ball like that looks like a fatigue failure from the ball not being able to move, or bad casting, or both? I've seen them separate when the ball wears out the nylon liner but not where they snap off like that.Definitely posting here too often, but I had another failure I didn't expect.
Could've been real bad, just managed to steer away from barriers by giving it some extra.Yikes, that could have been really bad.
I have a sticky door lock on my pass rear door. I've noticed that in colder weather that lock sometimes will not completely move to the locked position. This causes the doors to unlock a couple seconds later. I have to manually push it to the locked position and then hit lock on my key fob for all my doors to stay locked. Luckily it's a rear door which doesn't get used unless I'm hauling my dogs. I would open all your doors & make sure they're all unlocked, hit the lock button on your key fob, and check to see if any of those locks did not fully move to the locked position.I'm getting a weird symptom on my '07 LX: when I hit the door lock button on the fob, the doors lock but the alarm doesn't set, and then in a few seconds I hear the doors unlock again. Unlocking and opening/closing a door seems to cure it in the moment, and then it'll happen a few hours later. I'm scratching my head on this one. Do I have a sticky door lock, a bad connection in one of my doors, an alarm problem, or ... ?
Likely it’s a weak door lock actuator (motor). When one (or more) doors don’t lock, you won’t get the “chirp”.I'm getting a weird symptom on my '07 LX: when I hit the door lock button on the fob, the doors lock but the alarm doesn't set, and then in a few seconds I hear the doors unlock again. Unlocking and opening/closing a door seems to cure it in the moment, and then it'll happen a few hours later. I'm scratching my head on this one. Do I have a sticky door lock, a bad connection in one of my doors, an alarm problem, or ... ?
Wait? We're supposed to get a chirp?Likely it’s a weak door lock actuator (motor). When one (or more) doors don’t lock, you won’t get the “chirp”.
Perhaps you should use 2 fewer ugga duggas in the future?Here's probably my worst one. Happened last spring. Broken lower alternator bolt...drilling this one out was worse than the time I broke the starter neck off in the block...
You may be on to something. My wife says every time I fix something I break something in the process.Perhaps you should use 2 fewer ugga duggas in the future?
In the US, a chirp is a “luxury feature” only available on LX 100 series. A little retrofitting is required to put a chirp on a LC 100 series.Wait? We're supposed to get a chirp?
All my doors lock but I don't get a chirp.
Whew, I was afraid I had a another fix-it project coming up.In the US, a chirp is a “luxury feature” only available on LX 100 series. A little retrofitting it required to put a chirp on a LC 100 series.
Only available on Luxury CrossoversIn the US, a chirp is a “luxury feature” only available on LX 100 series. A little retrofitting it required to put a chirp on a LC 100 series.
And plebeian (4th gen) 4Runners.Only available on Luxury Crossovers![]()
