Just went through a knuckle rebuild about 2500 miles ago - installed upgrade Marlin seals, new knuckle bearings, wheels bearings, moly/lithium grease, front diff oil...the whole 9.
Went slow, seemed like everything went well. Set the seals with a small seal driver that fit fine, nothing made me question the installation....until I was under the truck this weekend replacing a clutch cylinder and saw fluid weeping from the bottom bearing caps on both the driver and passenger side. The passenger side is the worst, actually has fluid on the threads and a drop or so a day coming off. The driver side has that saturated look around the same area but isn't wet to the touch.
The back of the knuckles themselves are nice and dry on both, no birfy soup coming out. As the seals are the only thing separating the gear oil from the outside world I clearly screwed it up somewhere but can't visualize what or where.
Any ideas?
Any ideas?
